My battery is good, the comaq presario C700 DC power jack is good and my power cord is good. the indicator light on the port is glowing and on the bottom left hand side of the screen has the plug in picture next to the battery is indicated, but its not charging and battery is dying... so what do you think?
Mt likely your battery is bad- remove the battery, drop it at a shop they will charge it and check it for free. Also have them check your pc. I will venture from experience your pc connector is cracked inside the case where you can't see it. I of course can by wrong but experience tells me i am right IF the battery charges at the shop.
Best of it and thanks for choosing FiX Ya
Gary
Check your DC Power Jack which is where the power cord plugs
into the computer is bad. Take an ink pen and push the tip inside the
jack and see if the little pin wiggles, if so the jack is bad. You'll have to
take the laptop apart to fix it. Most times it is soldered onto the
motherboard, so you will have to desolder the old and solder a new one.
into the compute. Take an ink pen and push the tip inside the
Take an ink pen and push the tip inside the jack and see if
the little pin wiggles, if so the jack is bad. You'll have to take the laptop
apart to fix it. Most times it is soldered onto the motherboard, so you
If the DC Power Jack is bad, then eventually the battery is going to die and you won't be able to boot your laptop. If the dc power jack is bad, the ac adapter power cord can't charge the battery.
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
