Question about Crown CE1000 2-Channel Amplifier
Clip led We have a CE1000 in our studio, channel one is dead and the clip led stays on. I have an electronics background any pointers would be a great help. Jim.
    Genius:
  • 3,422 Answers
HI,
I believe that the channel might have been blown up.So the best solution is to get it service and that's the only solution to fix your problem.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 07, 2008
  • 4,234 Answers
That particular channel is blown. These are not the easiest units to repair. Given that this is a commercial amp, I would recommend that this unit be brought to an authorized Crown service center for repair. Expect parts cost in the $50 range plus the labor charge.
Dan
  • ABRsvcs Apr 07, 2008
    I looked into this model a bit more... This one uses at least 2 stages of output power so the output design is non-standard. If you are not familiar with Crown designs, please seek assistance at a servicer. If you have specific questions, I can answer them.
    Dan
Hi,, the stop button and channel one on my korg d3200 are almost dead , can i order the parts and replace at home and is there a tutorial about taking off the faceplate etc thx andy
Unless you are electronically adept and have certain tools I would NOT attempt this yourself. You could damage the circuit board causing great repair expense.
Feb 23, 2011 | Korg D3200 Studio Package
Crown CE1000 and CE2000 both clipping with low signals
for some reason channel one of one of our amps started clipping. i first noticed it with the drum kit but it slowly moved to the vocals as well. i haven't noticed this issue before today. what do i need to adjust to keep it from clipping?
Jun 04, 2010 | Crown CE2000 2-Channel Amplifier
CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Apr 05, 2010 | Crown CE1000 2-Channel Amplifier
Adcom GFA-7400 power amp; 1 dead channel (thermal protect LED on)
Hi...
I've contacted ADCOM before and they sent a pdf of the electricals
http://www.adcom.com/default.aspx
also try:
www.stereomanuals.com
Mar 30, 2010 | Adcom GFA-7400 5-Channel Amplifier
Right channel dead
Check the gain control in front panel. The material use inside them is pretty thin and weak, an could break loose when hurting during manipulation.
Spider Guy
Mar 11, 2010 | Crown CE1000 2-Channel Amplifier
My yahama P3500s Amplifier left channel dead and clipping light stays on both speakers works ok in right channel.
Hi, make sure everything is disconnected, is the clip light still on?
if so then I'm afraid it sounds like the output devices for one channel may have blown, ( not certain, without looking at it i'm afraid ).
If you need more help, then please ask.
Regards - Anthony
Feb 06, 2010 | Yamaha P3500S Amplifier
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
Left channel erratic
You may luck out by using a spray can of electronics contact cleaner and spray the controls through the front end. If you can take the knobs off, that would be good.
You can purchase the contact cleaner in an electronics store such as Radio Shack.
Jul 05, 2009 | Crown CE1000 2-Channel Amplifier
Ce1000
Feel free to request specifics if needed.
Dan
Apr 11, 2008 | Crown CE1000 2-Channel Amplifier
Crown CE1000 2-Channel Amplifier Logo
155 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
