Question about Stairmaster 4400 PT Stair Stepper
The chain slips when using the machine - both sides.
When the chain slips there is a loud noise, possibly indicating the chain has slipped and then caught again.
    President:
  • 832 Answers
This could be the hub assembly slipping I would replace this assembly and the pedal chains call National Gym Supply @ 800-496-7278 and get pricing for the hub assembly and step chain ( L & R )
Posted on Jun 01, 2010
The chain feels like it is slipping and a clunking noise when it slips.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This can be caused by either a loose chain, a failing chain tensioner or possibly, a failing transmission. You can find some troubleshooting information at the following link.
Search Results
Nov 08, 2015 | Stairmaster 7000PT Nautilus Stepmill
4wd messed up in dodge 1500
inspect for worn components from output of transfer case to front diff input. If everything is tight and solid from those two points, everything else points to being transfercase internals. Make sure your actuator isn't faulty causing a "4x4 to 2x4 shift on/off"
Dec 13, 2013 | Dodge Cars & Trucks
Kirkland saws800mq0 washer will not spin and makes a loud noise in spin cycle
Possible that the belt is slipping on load or there is problems in the drive. You can remove and reset the drive and belt or even replace the belt if this is slipping , click on Belt replacement.
Jan 17, 2013 | Washing Machines
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
3 Remove the lint trap from the lint compartment on the top of the dryer.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use .
Aug 02, 2011 | Washing Machines
When i accelerate there is a loud clanking sound from engine i guess
Possible the faults can be related to the following:
1. check the clutch settings- if the clutch is slipping this noise can come up. release the clutch very slowly and check if the noise reduces.
2.Possible that the drive links, the drive shaft , bearing assembly is faulty.
3. Possible there is loose linkages on the brake assembly which could get into the movement of the wheel and make noise.
4. The noise can be within the engine, possible that the belt slipping, water pump bearings, alternator bearings or idler units.
Mar 03, 2011 | 1995 Mitsubishi Diamante
Stairmaster freeclimber 4400pt how to fix slipping chain. When using the machine the chain slips intermittently on both sides. Problem was infrequent in the beginning but getting worse all the time with...
May 25, 2010 | Stairmaster Exercise & Fitness
1999 neon making a loud screeching noise under hood passenger side
It sounds like you have a belt or pulley problem, or possibly a bad bearing in the alternator, or water pump. I would suggest, having it looked at, by a mechanic right away.
Apr 24, 2010 | Plymouth Neon Cars & Trucks
Chain Slipping
Your chain would have to be incredibly loose to slip the sprocket. Enough that it would come off the bar before jumping the teeth on the rear sprocket. Highly unlikely.
Jan 01, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I was driving the car, then it made a loud noise the whole motor was shaking. then would not turn on
SOUND LIKE TIMING CHAIN JUMP TIME BECAUSE IT WORN HAD A LOT OF SLACK CAUSING IT TO SLIP TIME.THE LOUD NOISE YOU HEARD IS THE ENGINE BACKFIRE.
Oct 25, 2009 | 1999 Oldsmobile Alero
Slipping
Your rear sprocket is worn. As your put the pressure on the pedals the chain is riding over the teeth and makes a crunching sound. The teeth could appear slightly hooked. You will probably find this does not happen in a different gear. You need to replace both the cassette (rear sprocket assembly) and the chain together because the chain wears to match the sprocket and if you just replace one you will still get the slipping. The front chain ring also wears but at a much slower than the rear so check it as well. Also check the rear derailleur that it is tensioning the chain correctly and not damaged or if the bike is a single speed the rear wheel is positioned to give the correct chain tension.
Sep 20, 2009 | Cycling
Stairmaster 4400 PT Stair Stepper Logo
418 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
