Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Gas/oil ratio mixture; chain oil lubricant
Homelite Pro 4620C Chainsaw: Need
1. Ratio of gas/oil mixture ?
2. Oil mixture, use 2 cycle ?
3. Chain saw lubricant - 30 SAE ??
  • 3 Answers
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
Posted on May 26, 2010
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
My saw runs a few minutes then gets hot and wont start
What is the ratio of the oil/gas mix?
Sounds like it is not getting sufficient lubrication.
Add 1/2 oz (about 1/2 shot glass) of 2-cycle oil to the gas tank and try again......
Check to be sure that you have LOTS of chain oil in the chain oil tank!!
\Keep us informed, please! -Jim
Oct 22, 2009 | Homelite ZR10926 16 Chain Saw
Trying to determine gas-to-oil ratio on a chain saw.
Confirmation to #1: Recommended for all McCulloch chain saws at 40 to 1 ratio. 3 oz. per U.S. gal.
Jun 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Chainsaw gas/oil mix ratio
I have two Stihls that are well over 20 years old. I use the factory recommended mixture, 1 part 2 cycle Stihl oil to regular gas. (1:50)
That is still what the factory recommends. Don't use a cheap 2 cycle oil, go to a Stihl store and buy their 2 cycle oil in the orange plastic bottle.
Jun 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Apr 26, 2009 | Remington 16" Electric Chain Saw
Gas to oil ratio for chainsaw
You will want to mix at a ratio of 40:1. that is 40 parts gas to 1 part 2-cycle oil.
Mar 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
1,300 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
