Question about Nikon Coolpix 2100 Digital Camera
Lens wil not open. Turn camera on and it gives you a "lens error"
    President:
  • 1,382 Answers
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Thank you !!
Posted on May 26, 2010
My new panasonic lumixDMC-ZS8 14.1MP Digital camera gives me system error (zoom) when I turn it on.the lens will not open?
The systems control board has detected a fault wth the lens, over time dirt and grime collect in the len causing havoc, the other concern is the gears have jammed or got damaged, either way it is a major dis-assembly and it will be expensive.
Mar 20, 2012 | Panasonic Cameras
My cannon camera lens will not open when i turn it on.
you will have to take the camera to a service station to get the lens repaired. the motor that drivers the lens is damaged giving the above error. thanks
Apr 20, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens won't open, & it says lens error, restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
The lens on my Cannon SD sure shot wil not close
Lens errors are fairly common for all digital cameras. Usually it's sand (be careful at the beach) or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
My camera lens on my cyber shot wont open
dont ask here, con men at large!! they will take your money, and give no you answer :(
Mar 17, 2009 | Sony Cyber-Shot DSC-S85 Digital Camera
Kodak c330 Lens Wont Open
Maybe this Link
http://www.fixya.com/support/t102982-e_18_problem
could give you some ideas to look at with you camera . It seems if thing are not lined up just right with the lens. I could see things stalling on these digital cameras.
Mar 11, 2009 | Kodak EasyShare C533 Digital Camera
Powershot A80 error E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 05, 2009 | Canon PowerShot A80 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix 2100 Digital Camera Logo
85 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
