I have a fujitsu fi-5990c scanner It powers up goes through initialization the top receiving tray is having trouble setting up then kicks it an error code "E 4"
  • tbstmc May 26, 2010
    Thanks for the help
  • 2,069 Answers
I will tell you this:
When any error occurs, the operator panel indicates [J] or [U] and a number alternately for temporary errors, or [E], [F], [C], [H], [A], or [L] and a number alternately for device alarms (permanent error). Temporary errors can be solved by the operator, but the device alarm require recovery works by support engineers.
Do you have the "Error Recovery Guide" installed on your computer?
HINT: The Error Recovery Guide is stored in the Setup CD-ROM.
your error seems to be a permanent error. however, Close the ADF completely and load the document again. then test
Posted on May 26, 2010
  • Muzahura Frank May 26, 2010
    If the above didn't fix it, then specifically, Error "E4" now points to the "motor fuse malfunction". you may have to contact operator support engineers for this.
Code EF 5120c
"EF error" in Fujitsu fi-5120c scanner refers to Background changeover unit failure. This error is detected in initial checking at power on.
Probable causes:
- Defective Control PCA
- Insulation material damage of BW motor cable or the damage of the wire in the motor.
Check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2.Are the cables between the Control PCA and the BW motor damaged? Or are the connectors connected correctly? Confirm the position of the BW motor and check the cables.
3.Is the CCD cable F or B damaged? Or are the connectors connected correctly?
If the above information doesn't help, then you are recommended to visit the nearest Fujitsu service center for assistance.
Thanks & regards,
ScanCare
Mar 03, 2014 | Fujitsu fi-5750C Flatbed Scanner
I receive an error F4 on my scanner when I turn it on. Will not scan. Any suggestions?
Hello Larry,
The F-4 error in Fujitsu fi-6240 scanner indicates Background change over unit malfunction alarm. It may be caused by the malfunction of background motor or optical unit or damaged optical cable.
You are recommended to contact the nearest Fujitsu scanner service center for rectification.
Thanks & regards,
ScanCare
Sep 25, 2013 | Fujitsu Fi-6240 Flatbed Scanner
A1E error code. We have a fi - 5900c scanner and its throwing a A1E error code. it will not initialize correctly. I sounds like the motor that moves the exit try will not stop moving up and down. we took...
I think you mean E1A which is the code of Death for a Fujitsu 5900C
It normally means get your big fat wallet out and buy a big fat large PCB for £1000's of pounds . But there is a Cheaper fix by miles .
Jun 11, 2012 | Fujitsu fi-5900C Pass-Through Scanner
After installing the scanner I get a message that says "failure in initialization of scanner. Scanner is ofline or scanner power is off." I have checked all of the cables and the scanner is...
first most computers are plug and play, if yours is not then you need to load the software that came with the scanner, only then will the computer see the scanner
Mar 31, 2011 | Fujitsu fi-5120C
I have fujitsu 4120c and it doesnot work,it have error 8.can anybody help me
Error code 8 means the SCSI fuse is blown off. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable
- Other SCSI device malfunction
Check if the SCSI cable or other SCSI devices connected to the scanner cause this error.The scanner can work even after this error occurs.
If the issue persists, you may have to contact Authorised Fujitsu Engineer to rectify the error.
Hope the above information is helpful.
Thank you for contacting Fixya.
Regards,
TechSatya
tech.satya@gmail.com
Nov 13, 2010 | Fujitsu fi-4120C Path-Through Scanner
How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Oct 27, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-4750C Flatbed Scanner
1.st step remove the software from the computer and then reboot. 2nd step install the software. 3rd step try a scan. Still in trouble? 4th step new scanner These items are not repairable.
Jul 01, 2007 | Fujitsu fi-4750C Flatbed Scanner
62 people viewed this question
k24674
jasbo
jasbo
