Question about Keurig B50 Coffee Maker
Won't power on.
Had unit approximately 9 months. Brewed fine this morning and it now kaput. Will not turn on. Tried numerous outlets.
SAME exact thing happened to me just this morning! No power whatsoever, like it wasn't even plugged in. I was so happy I registered it online when I got it. I called them today, told them what was happening. They made me move it to another outlet while on the phone, then plug a can-opener or something into same outlet, when that worked, put me on hold for about 30 seconds, and told me since I am within my year warranty, they are sending a new one! All I need to do is send the K-cup holder to them (but new machine already on the way). Give them a call! Get it replaced! Hope this helps
Posted on May 28, 2010
Vizio VL470M won't turn on
see this instruction: God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
3. test the power outlet wall see the diagram
4. do not use the r.control use the power button directly from TV.
Jul 20, 2013 | Vizio 47"" vl470m 1080p 120hz widescreen...
DCC-1150 Coffee Maker does not have power
Talked to Cuisinart tech support and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults.
It looks like a thermal fuse might have blown inside your appliance.
If a thermal fuse has failed, there is probably another problem inside.
If the appliance is 4 months old, still cover under manufacturers warranty, Call the Cuisinart customer service to ask them where to find an authorized service center.
Hope this works for you.
Mar 12, 2008 | Cuisinart DCC-1200 Coffee Maker
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
Coffe maker has shut off no power
Pad and Circuit board shorted. Return for replacement.
Jan 22, 2012 | Keurig Platinum B70 Coffee Maker
Quit working, unable to turn on unit
replace caps in power supply had same problem. 12volt line week reads around 9-10volts. 2 caps are 1000 at 16v and 47 at 16volts.
Apr 20, 2009 | Televison & Video
7410 HP MFC Shows no power.
If you mean that the power light isn't on, but the screen is stuck in boot-up mode, try this partial soltion; it's worked for nearly everone who's tried it. It's in reference to the officejet 7410 all-in-on, but I think it's worked for other machines. Unfortunantly, you lose your wireless capabilities, but at leat you're not left with a $500 paper weight:
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
(It's interesting that the majority of posts with this issue have occured on numerous sites during the last two months).
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Sanyo 50 inch plamsa just quit!
the power supply of the tv is too sensitive. you need to have a good spike guard for this.
Jan 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Pot keeps shutting off after coffee completely brewed.
This may be an electrical issue, but I would try holding in the on/off button for a few seconds and see if it still displays 2 hrs as the auto-off time. If 2 hrs does display correctly, unplug the unit for 16 minutes or longer - do not plug it back in a single second shy of 16 minutes. Then reset the clock and reprogram the auto-off Try one more time.
If that fails, it may be replacement time.
-Tha Mp3 Doctor
Nov 28, 2008 | Cuisinart DGB-500 Coffee Maker
My TV died this morning
Sounds like a power issue with the unit you will have to call the customer suppport line and have them refer you to an authorized dealer or send it back to them.
Aug 06, 2007 | Emerson EWL3706 37 in. LCD Television
Keurig B50 Coffee Maker Logo
333 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
