I am trying to find a light earphones maDE BY YOU THAT WAS SOLD AT THE SOURCE THEY WERE A SOLID PIECE YELLOW IN COLOUR AND WERE SUPERB NOT BUD TYPE BUT A SINGLE PLASTIC RING
  • 566 Answers
Posted on May 26, 2010
  • Jacques Marin
    Jacques Marin May 26, 2010
    To answer your question;
    We are in no way affiliated with "the source" , formerly radio shack (in canada at least) or manufacture any product.
    Probably your best option would be to contact "the source" and ask for future availability or the model number so you could do a search for that model. As they might be available somewhere else.
    Hope this help and good luck.
Have a 1988 Chevy Cheyene p?u with a Am radio in it now. Want to install a factory AM/FM radio. AM has a solid wire going to radio. How do I hook up AM/FM with clip?
Following are colour codes for your radio curtesy of;
Source(s): GM dealer tech over 30 years. HyperGforce
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
The solid wire (casing) would enclose a number of thinner wires that may or may not include these colour codes.
You have to match up the wires and their functions in your new radio with these colour coded wires, have fun..........
Oct 16, 2017 | Car Audio & Video
Replacing minijack
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
Apr 11, 2014 | Klipsch Image S4a black For Android In-Ear...
Need 91 holden apollo stereo wiring diagram or wire colour codes.
We have access to many radio diagrams but his is not one of them because this isn't a make sold in the USA.. See if a local source has the info. We are a US based site
Jun 28, 2012 | Holden Apollo Cars & Trucks
I plugged my earphones into my ipod and laptop to play music, and the music comes out of my left earphone, but not the right
This could the way the music is been recorded if it is strero or mono, also do confirm the earphone if one side of the earphone is faulty or not, if bad replace with the exact type and if not the media itself is faulty, you can take it the an electronics repair shop for them to diagonised the appliances... Hope this will help in solving.......
May 06, 2011 | JVC Gumy Ear Bud Headphone - Peppermint...
Were can i get a free diagram of the wirering for the lights for a ford focus h/b 2003 so i can fit my towbar.. just the wirering in the boot
Go into the boot and access the tail light clusters under their covers in the boot rear corners. Take a lead (you can buy double adapter spade connectors) from (1) a tail light, (2) a brake light, (3) the right indicator, (4) the left indicator. (5) a solid earth wire. Try using different colour wires, making a note of each source and each corresponding colour. Tape them together and lead them to the trailer plug. There is a set international configuration for the trailer plug connections which is shown below.
Apr 06, 2011 | 2003 Ford Focus
I have a 2002 Suzuki Swift 1.3 and I need the colour coding for the car stereo. This is how it looks like looking from the back of the connector. The top colour is the main colour and the bottom is the...
why post non usa cars to USA forum>????
hint, we dont have M13 here. (EPA ******* here)
then not telliny your county.
why"?
my guess is you think all cars same, all suzuki same world wide and all suzuki have 1 radio.
sorry that don't fly.
but most posts here are just like this, hopeless.
wild guess 1:
here is our last swift, sold USA.,(not a m13 for sure)
wires
MAin set; and speakers last.
wht/blk, = ign. on. power 12v
white = memory , hot all time to battery via fuse, station memory
black = ground
red-green = illumination
red-yell = park lamps on, lighting,.
and below is speaker.
this is year 2000 last car sold here,
Mar 13, 2017 | 2001 Suzuki Swift
Battery back-up doesn't hold power...
there are 3 possible reasons why you are having this type of problem.
  1. The power source or outlet might be having a partial contact. try to plug your UPS into another wall outlet socket (Not an extension socket). observe the behavior. if it persists, try to change your UPS power cable (It might have short circuit somewere that is not allowing the UPS to charge properly) If this fails too, try the next step.
  2. The solid yellow light means 2 things. either you have a problem with your batery or your battery is dead and needs a complete replacement.
  3. Either way, get another battery and try it out. Before you change your battery, try using the UPS on another PC and observe the behavior. the fault might be from your PC. if you observe the same thing, then you may need to get another battery. Cheers!
Apr 15, 2009 | Computers & Internet
System does not start
The beeps are error codes and if you listen carfully you will hear a pattern of short and long beeps. If you can identify the pattern we can help you figure out whats going on....
Feb 14, 2007 | Dell OptiPlex GX110 PC Desktop
Earphone Connection
If you feel comfortable taking apart micr electronics then you can take off the case ans disassemble the chassis and see if its just the solder connections on the pcb. but be carefull sometimes they use flex pc boards and too much heat will burn up the board and then your dead in the water. Also it could be that the solder trace could have broken off the pcb. if this happens your gonna need to solder on a piece of small solid copper wire like phone cable (cat three type 26 guage)and run the other end to another solder connectionon the same trace. Them what I do is epoxie the connections and the jack so that its secure. Good Luck
Apr 27, 2006 | Creative Labs Zen Micro MP3 Player
149 people viewed this question
 Grubhead
Grubhead
