Question about LG 47LG50 47 in. LCD HDTV
CANT CONTROL TV
IT TURN'S ON BY ITSELF MENU SCREEN POP'S IN AND OUT REMOTE CONTROL WONT WORK MANUAL CONTROL BUTTONS WONT WORK. TV IS 1YEAR OLD
I am currently experiencing this exact same problem with my 47LG50. Since the original thread was posted more than three months ago, I imagine the original poster has had his/her issue resolved, but I can still relay what LG told me to try when I called them. Did it work for me? No. I have to call The Geek Squad with Best Buy (as the TV is no longer under manufacturer's warranty, but thankfully, we bought the extended warranty with BB), but it could work for some, according to the representative I spoke with.
Try taking the batteries out of the remote, and see if this resolves the issue alone. If not, try unplugging the TV entirely and holding the power button down (it's just under the power light, carefully hidden, and shaped like a smile) for at least 40 seconds. After that, plug the TV back in and power it up to see if it has resolved the issue with the flashing menus. Even if it seems to have done, you might want to leave it on and keep an eye on the screen for a while. I had mine abate for a little bit, but then it went right back to flashing menus. The issue of it powering on by itself will be pretty easy to notice if it is still doing it.
I hope this helps someone, although it didn't work for me. =)
Posted on Sep 09, 2010
  • Edmund Brown Feb 24, 2012
    Hello, what else did you do, as i have tried what you have said and have not gotten anywhere either
I have a Philips 42" LED flat screen about 5 years old, all of a sudden when you turn it on I get the settings menu, when I try to click out it will bring up the picture and then within seconds it...
Tv have a shorted IC that control the manual control board side of the tv itself or the manual control board itself it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control board.Replace the manual tv control board first to test it out.If u still have the same result the IC that control the board itself is dead,now must take to the shop for repair.
Jun 09, 2011 | Philips Televison & Video
My LG tv has a mind o its own. First off, the tv buttons rarely work. I have tried to reset it by unplugging all wires and holding power button for 30 seconds, but it solely temporarily fixes the problem....
The tv PCB board manual contol buttons board is shorted,that why u have ramdoom screen menu pop up.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tv manual PCB control board for the replacement.
Jan 14, 2011 | LG 42LC7D-UB Television
No sound, remote locked or not working?? and i cant get the menu to work on the tv itself, the volume is stuck on 0, cant move HELP
The buttons on the front of the set fail, (like mine did) even if they never get used. Probably the 'DOWN Volume' in your case is stuck closed. Try pecking on it first. My remote stopped working but so did the manual buttons too. While poking around on stuff I swished my finger across the buttons and it all started working so I knew I was on to something. I never figured out which one was the culprit as it continued to cause problems and was replaced as a complete unit under warranty.
The other quick check/fix is to remove the trim plate around the button plate (pop out stays like the speaker covers) , then remove the button assembly (3 screws plus pop out stays like the speaker covers) then unplug the multi colored lead from the button circuit board. This puts the Remote back in control and it will work just fine like this, minus manual control of course.
Jul 19, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) To Check if it was a success
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 21, 2008 | LG Televison & Video
LG 47LG50 47 in. LCD HDTV Logo
377 people viewed this question
Computer Repairing
Computer Repairing
