Question about HP DeskJet 5550 InkJet Printer
Hp deskjet 5550 is always had a paper jam. what do you think is the problem of my printer? what is the possible solutions?
  • HP Master
  • 32,281 Answers
When removing a sheet of paper from a jambed printer, you need to be careful to slowly remove the paper without tearing the paper. This could lead to a tiny piece of paper being left behind and this will cause other paper jambs.
When this happens, the printer may need to be dismantled to remove the paper.
The other cause could be that there is uneven pressure across the rollers or dirty rollers which causes the paper to feed through unevenly and results in a paper jambs.
Check the printer for pieces of paper near the rollers and gears.
Clean the rollers, make sure there are no deposits on the rollers.
Posted on May 26, 2010
I have hp deskjet 5550 printer,when i was trying to print a document there is no print out, two lights are blinking
Hi, This could be Low-Ink or paper Jam. Try turning off The printer, Unplug from The Mains Electric, for 3-5 Minutes. Turn back On, if Lights Are Still There. Check The Ink-Levels. And Replace Cartridges, if necessary.
Mike.
Jun 02, 2011 | HP DeskJet 5550 InkJet Printer
Paper jam
check if there is any piece of paper is jamed inside your printer i think that is why your printer always says paper jam
Jul 08, 2010 | HP DeskJet F380 All-In-One Printer
Printer status states paper jam although there is
Have you check the rear side of your printer?
Try the below..maybe it will help...
Disconnect the USB cable or parallel cable from the rear of the product then turn off the printer. Turn the knob on the rear access door counter clockwise, and then pull the door out to remove it.Check if there is any paper there..
May 24, 2010 | HP DeskJet 5550 InkJet Printer
I have an HP deskjet 5550. I had a paper jam earlier but cleared it. After reseting, warning light still comes on. Printer makes clicking noise when I first turn it back on.
First off how long have you owned the printer? There are several possibilities at this point. Possible paper still jammed or damage done to a part while clearing the jam. Once I have more information I can assist you further.
Thank you,
Lee
Feb 01, 2010 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
Both my printer lights are flashing and I have tried all the
Open the back panel...check to see if you have a paper jam....
if not open the link below and follow instructions
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00681585&lc=en&dlc=en&cc=us&product=71896&rule=23659&lang=en
keep me posted
Please do not forget to vote!
Cheers!
Nov 13, 2008 | HP DeskJet 5550 InkJet Printer
My printer always jams paper?
go to manufactures website and reset your printer
Mar 11, 2008 | HP DeskJet 5550 InkJet Printer
HP 5550 Print issue
When you removed the jammed paper , the jam paper sensor was not reset or positioned correctly. The reason the machine was sending two pieces of paper thru at once was probably due to the paper feed sensor. A lot of H'Ps do this. Try re-aligning the tray and if you pulled the paper out and heard a grinding noise, the whole feed unit is probably out of time.I would only re-install the software as a last resort, since your problem was caused by hardware, not software. Scrivitron
Jun 20, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
192 people viewed this question
Seeker5211
Seeker5211
