Compressor for air will not cycle on.
I have a Lennox G40UH(X) unit. ComEd the electical provider, came and installed an auto monitor and breaker on the feed line that enables the power company to turn off my units for 1 hour during peak time if necessary. One unit works the other does not. The contractor for the power company came out and could turn on the compressor manually from outside, he indicated that the signal from the furnance/thermostat was not triggering the compressor to turn on. We get the furnace fan to turn on, yet the compressor is still a no go. The thremostat is a Honeywell RTH6400, has 4 wire connection. I check the wires and all are properly installed and tight. Had no problems with the heat. Suggestions?
    Novelist:
  • 117 Answers
Check and see if you have a common wire on the thermostat. If you do not, then you will need to replace batteries if applicable.
If you do have a common wire, then batteries are not necessary for thermostat operation.
Even though the thermostat wires are secured properly and the thermostat worked fine in the heat mode, it doesn't mean it will work for the AC mode.
If you want to check the thermostat in an easy manner, you will need to jump out the Red and Yellow terminals at the thermostat. Be sure to turn off power first to the furnace. After jumping out, restore power to furnace. If the unit comes on, then your thermostat is bad. If the unit fails to come on, you have another issue. You can repeat this process at the outdoor unit with the low voltage lines if you feel capable. If unit comes on, your problem lies between thermostat and outdoor unit. If your unit fails to start, your problem lies within the outdoor unit.
Be sure to check any drain pans, float switches, or cut-out safeties installed that may cause this. Many contractors will wire in drain safeties to the outdoor unit to shut down the compressor in the event a drain line has clogged and backed up into the emergency pan. Of a condensate pump has failed.
If you do not feel you are capable of this, you may need to contact a local professional to come diagnose the situation. But those are a few simple tasks that you can complete yourself to narrow down a problem.
Posted on May 26, 2010
Testimonial: "All good suggestions, but still no luck"
How many BYU is a Lennox G40UH (x) series furnace? And can it be vented with PVC? Thanks alot!
The Btu rating for this furnace is 40,000. Since the furnace has a 3 /34" metal flue collar on the top of the unit, you can not use PVC pipe to vent it. Only 90+ efficient gas furnaces can use PVC pipe for venting and the also come equipped with a condensation pump, which yours doesn't.
For more information on your furnace and how it's to be safely installed and vented, here is a link to the installation manual http://www.greenwoodheating.com/products/manuals/gasfurnaces/G40UH.pdf that you can download and print.
Hope this helped answer your questions?
Mar 18, 2011 | Heating & Cooling
Lennox G40uh model, blower work, but does no ignite.
Jump out the pressure switch once the inducer blower starts. If it lights, you have a bad switch or the vent is obstructed. Is the unit blinking any error codes at the PC Board?
Mar 07, 2011 | Heating & Cooling
Intertherm S3QA042K compressor won't restart
You probably need a hard-start kit. A hard-start kit connects to the run capacitor and provides a starting boost for your compressor. If you install a hard-start kit, monitor your a/c for a while because it is possible that the bearings in the compressor are going bad.
Jul 30, 2009 | Heating & Cooling
No cool air some rooms: Lennox G40UH
Sounds like a restriction of air flow. Check you duct work and check for holes or lose duct.
Jun 30, 2009 | Goodman CKL24AR24 Air Conditioner
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
Heating & Cooling Logo
227 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
