Question about HP dx2300 Monitor Personal computer Intel Core 2 Duo Processor E2160, 1 GB RAM, 80 GB Hard Drive, ... PC Desktop
I loose picture while using the computer, I have
I loose picture while using the PC screen, I have to press the on/off switch about four times before it will come on again. Do I have switch malfuntion problem and will I have to have it fixed
    Scholar:
  • 130 Answers
It does sound like your switch is going bad. I doubt that it would be worth paying to get it fixed.
I am assuming that once it is on that it stays on. If so, I would just leave it on. Assuming that the monitor is fairly new and if it is Energy Star compliant, you should not be drawing much power when the CPU is off.
Hope that helps.
Posted on May 26, 2010
Testimonial: "Thank you for your advice, it seems like the right solution, I appreciate your quick response to my question"
My proline laptop doesn't want to show up screen but it is cahrging but it can't switch on screen please help
The "black screen of death" is usually very easy to repair on a laptop. First turn your computer off by pressing and holding down the start button. Next unplug the computer and then remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer. Press the start button and the display should return. Replace the battery. If this does not work, try it again up to four times. No results usually indicates a bad mother board. Hope this helps.
Mar 05, 2016 | Computers & Internet
Why the black screen on my pc?
It really could be a lot of things. The four that immediately spring to mind are
1. Your screen is broken
2. Your computer is slow and is going through a cascade of data which may take a long time. Leave it alone and come back to it in an hour. Or even 2 hours.
3. Your Video driver may be corrupt or missing. If this is the case, a new driver needs to be installed. This is difficult when one cannot see the screen to do it.
4. The Function key for sending the feed from your laptop to a third party device, like a projector, is enabled. Your computer thinks you want to use it to send the picture to another device. You should hold in the Fn key, down near the bottom left CTRL key. and while holding in that Fn key, press the Function key (F key) across the top of the keyboard that shows a little picture of a television screen. Press it once and wait to see if your screen returns. If not, press it a second time... If not, then this is not the problem.
May 22, 2014 | Toshiba Computers & Internet
Where is the LCD cutoff switch located ?
Both the D620 and the D630 use the same keyboard.
The picture below shows the keyboard.
Hold down the blue Fn key at lower left, and then press F8 while holding down Fn. Press F8 multiple times until the screen returns.
If that fails, the ribbon cable connected at the main board from the screen may be loose and removing it, then reconnecting it, is the most likely solution.
ixquick proxy com
May 17, 2014 | Dell Latitude D630 Notebook
Cannot connect compaq presario v400 to tv
Did you mean you want to connect your computer to a TV?
If you did and connected it but nothing happened then you may have to select the correct input on the TV remote. It used to be called AV but some of them have a little picture of a screen with and arrow pointing in to it from the left.
You just switch your TV on, switch your computer on, then press the button on the remote a few times until you get the PC input picture. You may also have to hold the Fn key on the computer and press one of the keys with a Monitor / TV screen symbol on it. It maybe one of the Function keys or one of the number keys at the top of the keyboard.
Feb 08, 2012 | Compaq Presario V400 14" CRT Monitor
I needed to re-install OS, etc on my Aspire 1360 and used the system disk and recovery disks. When I inserted the system disk for the second time, as prompted, all I got was four single bleeps at around...
Hi
please try pressing the ALT+f10 ON STARTUP
this may take you into the factory restore
if it asks for a password and you have not set one then the default is normally 000000 6 zero,s
then follow on screen instructions
if you have the option to save any files or pictures before you do this please do so if you need any saved as you will loose them if you do a complete factory restore
many thanks
Jul 18, 2011 | Acer Aspire 1360 Notebook
All funcions freeze.have to switch off and start again .crash's screen goes blank' it is only four monts old
Try to start the compute in safe mode, and check if the computer works without any issue, to access safemode, you have to press the F8 key while you get the Acer Logo.
Try restoring the Operating system by pressing Alt+F10 when you get the Acer logo and follow the screen.
Apr 07, 2010 | Acer Aspire One PC Notebook
How do i connect my pc to my tv
Yes it supports PC hook up. You can hook it in four ways using either an S-Video, HDMI or DVI connector.
  1. Connect the PC to your TV using either of the above connectors.
  2. Press MENU on the remote control and FEATURES > MODE SELECTION.
  3. Select PC and press OK to confirm your choice.
  4. If necessary, adjust picture settings.
  5. Set the picture format to Unscaled when using wide-screen PC resolutions.
  6. Press MENU to exit.
Oct 08, 2009 | Philips 47PFL3603D LCD TV
Screen frozen, control not working with computer.
make sure batteries are ok, sounds like it is not in sync.
thx
Aug 01, 2009 | Nintendo Wii Console
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
HP dx2300 Monitor Personal computer Intel Core 2 Duo Processor E2160, 1 GB RAM, 80 GB Hard Drive, ... PC Desktop Logo
37 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
