Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Unable to few drive no icon in mycomputer
Hi i have a Western Digital external drive when i connect it the CPU picks it up and i can tell by looking into Device Manager and seeing the drive but when i go into my computer i cannot c the drive icon to access it how can i fix this and is it possible that someone made my drive hidden by chance
  • rakeeshgray May 26, 2010
    Wat happens if it says uninitialized space ? wat then
  • rakeeshgray May 27, 2010
    i cannot access the drive when i go into disk management it says the drive is uninitialized upon trying to initializing it i get an error that says cannot intitalized so im unable to initialize it and also unable to format it ?? any idea
    Scholar:
  • 130 Answers
Can you see your file system on other machines? If so, we know that it is machine related.
However, I am guessing that the drive appears to be unformatted or has a different filesystem organization.
Go to
  • start
  • control panel
  • administrative tools
  • computer management
  • storage
  • disk management
You should now see the disk as Windows sees it. If it shows uninitialized space. That would be bad. It might show hidden partitions, etc. hat would be better. You might be able to change the status of the partition.
If you don't have any information on the disk. You can just reformat it by doing a right click on the disk.
I hope that helps you get a little closer to a solution.
Posted on May 26, 2010
  • Jack Briner
    Jack Briner May 27, 2010
    Sorry, I missed your reply. If you have no data on it, you should format in the disk management. As I recall, do a right click on the drive. Now select the entire space and format with NTFS.
    If you need more help, I will check for your response. If you get a chance, please rate my help.
My computer doesn't recognize my hooked in to 3.0 USB port on my ASUS laptop, initialized, SATA 2TG internal drive that's within an external case.
depends on the operating system but normally if you can see the drive in pc manager (right click mycomputer icon, select manage, select disk management in windows) if the drive is listed then format it and allow automatic drive letter assingment
Mar 20, 2014 | Western Digital WD Caviar Blue WD3200AAJS...
I can't access my western digital external hard drive to any computers..How can i do?
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Jun 13, 2011 | Western Digital Passport 320GB External...
I have 250gb WD external HDD , but after connect while initial it gives "the media is write protected" i am unable to access partitions
Right click on your My Computer icon and select Manage,
Now click on Disk Management.
Here you can see your Hard Disc partition.
Write click on any drive and format it. It will remove your write protection.
But Make sure it will delete all data on that partition.
May 11, 2011 | Western Digital (WD3200JS) 320 GB Hard...
Unit downloaded fine ad the did the back up of the drive fine.started the updates and the firmware stopped and then the drive locked up how to access the drive again after reboot nothing shows G: F:
  1. To restore the Western Digital icon to the drive letter for the external drive in "My Computer".
  2. Please go to the Western Digital Download Library and download the WD Logo Icon which has a file name of External Icon.zip when you download it.
  3. Save the file to your desktop and use a file compression software like Winzip to extract the files inside the .zip file to your desktop. When it's unzipped, it will create a folder named "ExternalIcon" on your desktop.
  4. Double-click on the ExternalIcon folder. It will open a Windows Explorer showing a folder named, Autorun, and a file named, Autorun.inf.Double-click on My Computer and it will open.
  5. Double-click on the driver letter that represents the Western Digital drive you want the icon on and it will open.
  6. Highlight the Autorun folder and the Autorun.inf file. Right-click on them, and left-click on Cut when the Menu appears.
  7. Right-click in the open space of the drive that you opened in the new Explorer window, and then left-click on Paste.
  8. Close both Explorer windows, safely remove the external hard drive by using the Safely Remove icon in the system tray, shut down the computer, and unplug the external drive from the computer.
  9. After you reboot into Windows, reconnect the external drive to the computer again, and the Western Digital Icon should now be displayed with the drive letter in My Computer.
If these steps do not correct the problem, you will need to re-format your External Hard Drive ***WARNING*** FORMATTING A HARD DRIVE WILL ERASE, YOU WILL LOSE, ALL DATA
Mar 18, 2011 | Western Digital My Book Essential 500GB...
Western digital external hard drive ,flashing green light when connected to the pc , stable when not connected , pc does not reconise hd , but picks it up in the bios
I take it that you are using USB 2.0, if so try another port preferably one at the back of the computer. Also check if the drive is present in MyComputer - Properties - Manage - Disk Management. If it, is make sure that it has a drive letter assigned to it.
Nov 03, 2009 | Western Digital My Book Essential 1TB...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
External Drive WD is not visible in Mycomputer.
right click on my computer
select manage
then disk management
identify the correct drive
right click and format,
once formatted remove
then plug back in,
you should beable to then see it under my computer
Jul 06, 2009 | Western Digital My Book Essential 320GB...
Defrag external ethernet had
Connect that to your PC. Go to MyComputer. Right click on the drive and select properties. Select tools tab and click on defragment now. This will start defrag process.
May 27, 2009 | Western Digital 500GB My Book World...
Cannot Read External Western Digital Mybook 500GB Drive
I have ".Window 7." Sometime I see a icon and it shows the drive size and can't read and my work. Yes, I do save my work on my hard drive, but I also want to save it on my external drive. . I even reboot.
Jan 13, 2009 | Western Digital 500GB My Book World...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
260 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
