Question about Iomega 10919 (10919WO13300) External ZIP Drive
I am running Windows 2000 sp4 My Zip drive is on an A/B switch w/ my printer. If I boot w/ the switch in the incorrect position, is there any way, after I change to the correct switch position, that I can make Windows detect the Zip Drive. Thanks
  • 1 more comment
  • ethros May 26, 2010
    Thank you.
    I think it would be possible to have Windows detect the Zip drive after boot. DOS and Linux can. Does anyone have more ideas?
  • ethros May 30, 2010
    Everyone is assuming that I cannot detect the Zip drive on boot. THAT IS NOT TRUE! I need to detect the Zip drive AFTER BOOT, since it was not connected at the time of boot.
    Please look at the whole trail of questions and answers.
  • ethros Jun 13, 2010
    Lets try this again...
    A Zip drive us NOTa PnP device. I need to detect it AFTER the computer has booted. In DOS I can run guest.exe to do it.
    What do I do in Windows 2000. Please do not tell me to reboot. The Zip drive will be automatically detected.
    One more piece of information that might help us both find the solution, is how do I do a sequential boot into Windows 2000? In other words, examine and see every instruction in the boot process.
    Thanks.
  • 493 Answers
You can try these options:
1. At the beginning you can switch it to zip then start your computer. when you need to print you can switch and set the printer enable from the contol panel or printer properties to be able to print without rebooting. If it doesn't work try to do followings.
2. To have the zip drive detected after boot, tell W2K to use legacy PnP mode.
Right-click My Computer
Click Properties
Select Hardware tab
Expand the Ports (COM & LPT) entry
Right-click Printer Port (LPT1) entry
Select Properties
In the Port Settings tab, select the Enable legacy Plug and Play detection option
Reboot
You may need to run the Add/Remove Hardware control panel applet.
Then try to switch from printer to zip drive. From my computer try to refresh the window, check the drive letter of the zip drive, if it is accessible or not without booting.
If it still does not work, try the following registry hack:
Click Start, and then click Run.
In the Open box, type regedt32, and then click OK.
Locate and then click the key that contains the values that you want to edit.
At the dos prompt type regedit and open registry editor
Hive: HKEY_LOCAL_MACHINE
Key: SYSTEM\CurrentControlSet\Services\Parallel\Parameters
Type: REG_DWORD
Value: 1
Restart PC.
Hope this helps
Waiting your comments.
Posted on May 30, 2010
  • 4,281 Answers
For that first insert zip drive into cabinet.
Then close the screw but let it loose into cabinet.Then check.
Set both screw to loose so zip driver can be detected in computer.
Also reconnect both cable to zip drive.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 26, 2010
  • 4 more comments
  • For that when you power up the computer press F1 or F2 or del or ALt+F2 key to enter in bios.
    Then you can see bios screen then go to boot menu and set first boot device as your zip drive then save settings and exit.
    Thank you.
    I think I did not adequately define the problem....;.
    Let me define the problem again. I boot the Windows 2000 computer without the Zip drive connected. I now connect the Zip drive. What should I do now to get Windows to recognize the Zip drive? What program should I run.
    In the same situation in DOS, I run guest.exe, and the DOS recognizes the Zip drive.
    Thanks again
  • For that go to device manager and uninstall floopy driver.
    Then if still same issue then
    First make sure cable connected to zipdrive is working fine.
    Press
    windows key +R key so you can see run then type in run "devmgmt.msc"
    then press ok so you can see device manager uninstall floopy zip drive drivers
    then it automatic install it's drivers.
    then check.
    Also you need
    to change registry for that type in run "regedit" then press ok then
    you can see registry editor then locate below key.
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
    And remove upper filter and lower filter.Then restart computer then check.
  • ethros May 28, 2010
    Let me define the situation again.
    What I am NOT trying to do is to detect the Zip drive on boot.
    This is the sequence:
    1] Boot computer w/o Zip drive attached.
    2] Attach Zip drive.
    3] Do something so that the computer will detect the Zip drive.
    The question to you is: "what is the something?"
    Thanks again.
  • Reconnect power cable and data cable to zip drive.
    If it is internal drive then change data cable which is connected to motherboard.
    Enter in bios and make sure zip drive or floopy drive is enable.
    Then save settings and check.
    One cannot access the BIOS w/o rebooting the computer.
    If I reboot w/ the drive connected, it will be detected. I wish to have the computer detect the Zip drive w/o a reboot.
    Thanks.
  • 32,281 Answers
I assume you have got a parallel port ZIP drive, if so -
The parallel port Zip drive was not designed to be connected by a A/B switch to switch between the Zip drive and the printer.
The Zip drive has two 25 pin connectors, one for connecting to the computer and the other for the printer.
The Zip drive is first connected to the computer and then the printer is connected to the printer port on the Zip drive.
Make sure the printer and the Zip drive are powered up first before you boot up the computer.
    Thank you.
    I am aware of the fact that the Zip Drive is a pass thru device, but I wish to retain my present configuration. On DOS 7.1 [the DOS underlying Windows 98], which I have on my other computer, I can run the "guest" program and it will detect the Zip drive after I boot the computer. [I also have an A/B switch there]. I would like to be able to do the same in Windows 2000.
    Thanks again
  • Chris Hingee
    Chris Hingee May 26, 2010
    I reasonably sure it won't work, Windows need to detect the Zip drive first.
    There may be a way around your problem.
    Install a 2nd LPT printer card in the computer, and install the printer on this card as a printer on LPT2 printer port.
    Connect the Zip drive on the original printer port (LPT1).
    Remove the A/B switch, you won't need it.
    Have fun.
I want a product information about jetflash v33
Download Links clip_image002.gif JetFlash Online Recovery (for Windows 2000 SP4/ XP SP2/ Vista /7) JetFlash Online Recovery (Only for V15; for Windows 2000 SP4/ XP SP2/ Vista /7) JetFlash Online Recovery (Only for JF620; for Windows 2000 SP4/ XP SP2/ Vista /7) User Manuals for JetFlash Online Recovery
Jan 09, 2013 | Electronics - Others
Ricoh afi 1022cio error code 101 need reset thank
Exposure Lamp Error
Symptom: The standard while level was not detected properly when scanning the white plate.
Possible Cause: • Exposure lamp defective
• Exposure lamp stabilizer defective
• Exposure lamp connector defective
• Dirty scanner mirror or scanner mirror
out of position
• SBU board defective
• SBU connector defective
• Lens block out of position
• Incorrect position or width of white
plate scanning (? SP4-015)
Jan 17, 2011 | Ricoh Aficio 1022 All-In-One Laser Printer
Running windows 2000 pro sp4. Using k8v-mx motherboard and installing new 320mb hard drive. Bios says drive is 320mb with lba set to auto but windows says 137mb. Do I need to instal a pci controler card to...
Windows 2000 only supports up to the 137gb. With some registry edits it may show all. Try to google "windows 2000 hard drive size" and see what you come up with.
Sep 29, 2009 | ASUS K8V-MX Motherboard
Can not install windows 98 on my gateway solo 9300
ok first your gona wana disable that ios password cuz wat that does is it locks some stuff up tht are critical to the system and then go in to your boot seequence and selct first boot device as floppy then 2 cd 3 hard drive and screw the rest then it should work
May 24, 2009 | Gateway Solo 9300 Notebook
Fujitsu Siemens Scenic T on windows 2000 Pro SP4
to fix it:
u should boot up with windows 2000 cd
go to repair windows then go recovery console from cd rom
now u'r in dos mode:
if u'r cd rom drive is d: and u'r hard disk is c:
just type this:
c:\copy d:\i386\ntldr
it's ntldr not ntdlr
then type:
c:\exit
u'r pc will restart and everything should work fine.
Hope this Helps. Regards Khushroo
Mar 09, 2009 | Fujitsu Siemens Computers & Internet
Windows xp 2002 sp4
Windows XP, the newest service pack for windows XP is SP3
Windows 2000, has SP1 SP2 SP3 SP4
There is no SP4 for XP.
If you need more asistance, let me know. Good luck.
Mar 31, 2008 | Microsoft Windows XP Professional With...
Driver for D-link WNA-1330
I haven't tried this yet, but I will check it out tonight:
D-Link WNA-1330 Driver 1.01 driver
Developer: D-Link
Version: 7.7.2
Filename: D-Link_WNA1330_driver_101.zip
OS: Windows XP,Windows 2000,Windows 2000 SP2,Windows 2000 SP3,Windows 2000 SP4,Windows NT,Windows Vista,Windows 98 SE,DOS,Windows NT SP1
License: shareware
ftp://ftp.dlink.com/Wireless/wna1330/Drivers/WNA1330_driver_101.zip
URL
http://www.driversforwindows.com/d_link_wna_1330_driver_1.01_9422.htm
Mar 05, 2008 | D-Link Wireless
USB 2.0 Host Controller on Windows 2000 Server (Emachine 5260)
raycrean, Windows 2000 service pack includes drivers for USB 2.0.
http://support.microsoft.com/kb/819332
How do you know its not operating like 2.0?
Jan 19, 2008 | E-Machines eMachines Desktop PC
Iomega zip drive problem
I'm trying to re-install iomegaware zip 100 & it tells me it does not support windows 2000 so I need to update drivers. Can you please help me figure this out as I rely on my zip for backups. I have version 21.1.
thanks very much
Marlene
Dec 31, 2007 | Iomega (32453) External ZIP Drive
Iomega 10919 (10919WO13300) External ZIP Drive Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
