Question about Radio Shack Pro-96 Scanner
I need to buy 2 lcd display boards for the pro 96 scanner. Where can I get them?
    Genius:
  • 1,274 Answers
You can get them at www.wearecb.com ...$21.99 ea. # 541-928-1952.....hope this was helpful...
Posted on May 26, 2010
Radio shack pro-96 scanner screen blinks and loss of audio
If the scanner's display locks up or does not work properly
after you connect a power source or install batteries, you
might need to initialize it.
This procedure clears all information you stored in the
scanner's memory. Initialize the scanner only when you
are sure the scanner is not working properly.
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Notes
Notes
Jan 10, 2013 | Radio Shack Pro-96 Scanner
The RS Pro 96 digital scanner radio locks up. The display comes on but the keyboard is nonfunctional. Nothing on the keyboard will work. Resetting the unit does not help. The lock function is not on. Not...
Check the small battery on the circuit board. Another possibility is that you don't have enough battery voltage to operate the unit. Even external power supplies may not produce enough voltage if the main battery is bad.
Aug 22, 2010 | Radio Shack Pro-96 Scanner
Lcd screen does not display
Connect the scanner to an external power supply that you know is good. Turn the scanner on, press "0", then "1" then "Enter". Count to 10 and turn the scanner off and back on. If the display does not return, it has failed and must be replaced.
Aug 13, 2010 | Radio Shack Pro-96 Scanner
Is there software for the pro 96 to monitar edacs
This scanner only monitors 2 of the 3 types of trunking systems. There is no digital voice inversion. There is an AGC control for the digital voice to try either way DG (on) or Dg (off) There is software you can buy to program the PRO96 from Don Starr. There are two Yahoo GrOUPS you can join to discuss this radio, in addition to forums on RadioReference DOT com.
73's
Jun 19, 2010 | Radio Shack Pro-96 Scanner
Pro 96 scanner only scans bank 3 and 4. i am sure
While it's scanning, press any keyboard number (0 thru 9) to activate/deactivate scanning on the corresponding bank.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc71/71778.pdf
For a comprehensive database of active frequencies and systems in your are,visit:
www.RadioReference.com
BillB
Jan 09, 2010 | Radio Shack Pro-96 Scanner
Need to reprogram hand held pro 96
Radio Shack can "CLone" your scanner with one in the store - try that first to see if it will work and let me know.
Aug 19, 2009 | Radio Shack Pro-96 Scanner
Bad lcd screen radio shack pro-92 hand held scanner
Do a google or yahoo search for gre america store. They may have the part you are looking for. If not they may be able to tell you where you can get the part. I know they carry parts for the pro 95 96 and 97.
Good Luck.
May 28, 2009 | Radio Shack Pro-97 Handheld Scanner
Which is the best sanner the pro96 or the pro106
I own both of these and like the 106 more. It isn't just because it is new, but it has several options that make it more "user friendly" as well as better features. Some of the high points are:
-Easier manual channel navigation
-Larger, easier to read display
-Easier scan list understanding
-Much better user interface (text menus)
-Colored LED that you can assign to different channels..such as your priority channels. This way you can see what your receiving at a glance without having to actually look at the display,
-Remote control capability using the Win500 software.
A Pro-96 is a good scanner, but the Pro-106 blows it out of the water.
Jan 26, 2009 | Radio Shack Pro-96 Scanner
Pro 96 Rebanding Issue
http://www.radioreference.com/forums/showthread.php?t=100208&highlight=custom+tables
You need to program custom tables into the Pro-96. Visit the link above.
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
815 831 25.000 0 846.625000
958 958 25.000 958 868.975000
961 1022 25.000 0 843.400000
Mar 15, 2008 | Radio Shack Pro-96 Scanner
Display is blacked out
I had the same problem with my Pro 96 display not displaying and followed thtough with Standers420's suggestion of taking the scanner apart and checking the ribbon wire from the board to the display. I put a little contact cleaner on my finger and kinda worked it into the leads on both sides of the wire, near each connection. Very carefully I might add. IT WORKED!! And it's really easy to do as well. So now for the first time in over 7 month's I have functionality back with my scanner. Because without the display, you can't actually use it to it's full capabilities. Thanks, Standers420!!
Jan 03, 2008 | Radio Shack Pro-96 Scanner
Radio Shack Pro-96 Scanner Logo
71 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
