Question about Golden Technologies Companion II Travel Scooter
Lights and horn work but companion will no move forward
  • 12,061 Answers
Hi, well these are quite simple devices really, Basically, a battery, a speed controller, and a motor. IF your horn etc, works OK, that proves there is some charge in the batteries, BUT that may NOT be enough. You need to check them with a meter set to Volts DC. They should read at least 12V DC. IF you have Battery Voltage OK, then you must check, ALL power connections to Battery, Motors, check for loose connectors. Finally, you will need to check your speed controller, This is usually the issue, You need to check and see if there is any Voltage coming OUT from the controller. and on the Motor terminals Below is a manual that will be of assistance. These can be quite tricky to sort out, in my professional opinion, one should get this attended too by professionals, you really should contact, Golden Technologies, .and ask for a referral to an authorised service center, then ask for a 'Quote" before proceeding with any repair.
http://docs.google.com/viewer?a=v&q=cache:2TOQtuRwZCAJ:www.goldentech.com/pdf/products/companion_manual.pdf+Golden+Technologies+Companion+II+Travel+Scooter+service+manual&hl=en&gl=nz&pid=bl&srcid=ADGEEShX7-aMAg5xUITTXZ6tc1DxoacTIVDf-05AK2QfUp97Ch5gZkZclyhtz079ulZK6Jf4dAKE4WDhkPzYQZLRPd_fBQtHw1GNAxYymTGvBpR0gJeVpdTjSkFNBT1QBQGO0SQaVEkY&sig=AHIEtbTcIvlVgzg8Sz4ZqQCAz0z2cCbx1g
Posted on May 26, 2010
THE BATTERY LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT AND CHAIR WILL NOT MOVE
Turn on Joystick and push horn twice, you are in locked mode. If this didn't work then turn Joystick on push gimbal forward until you hear a beep, then move the gimbal back until it beeps you are now unlocked. Gimbal= what you push to go left right forward or back on a joystick.
Jan 27, 2016 | Pride Jazzy Select Elite
I have a Golden Companion II, all power comes on:light, battery meter and horn but it won't move when I press the throttle. I do hear the click from the brake but it won't move forward or reverse. If its...
Tony Check the freewheel lever Make sure that the scooter can't be pushed easily. If you can push it then its in freewheel. Now Tony you could have a problem with the brake itself. There is a small micro switch on the brake that engages and disengages when you move the freewheel lever. If you can get a close look at it make sure that it still looks like its operating its a mechanical mech activated by the lever on the brake. If it looks ok and you can get the scooter in or out of freewheeling (the rear wheels lock and unlock) then it could be a throttle pot problem or a speed control pot problem. Fortunately you can't bypass the throttle or speed pot. You will have to get these checked by a tech either with your provider or a service company that has techs around your area. I'm sorry I couldn't give you a quick fix but scooters are more difficult to troubleshoot because of all the different componets necessary to make it go. Good Luck Hope this helps
Oct 27, 2010 | Golden Technologies Companion II Travel...
No forward or reverse. lights and horn work micro switch on brake has continuity with brake off batteries charged and all connectors reseated. Motor spins forward and reverse when voltage appled...
Joe with a scooter there can be a number of things wrong to cause your problem Since the motor turns and you have power at the console. It could be the throttle pot or the speed pot or both or it could be the cable that runs from the console to the rear of the scooter and finally a problem with the controller. But that would also give some sort of error to the console light if it is equiped with a power light. If Medicare paid for your scooter then they will pay most of the cost of repair. Your provider can work on it for you or they can contact a repair service that will fix it for you Hope this helps
Sep 27, 2010 | Golden Technologies Companion II Travel...
Fix mobilty scooter
This scooter should NOT work with the charger plugged in
Unplug and try
Apr 21, 2010 | Golden Technologies Golden CompanioN II -...
Golden Tech Companion II: Doesn't go, batteries
Accessibility Specialists Inc
1815 Corporate Sq Blvd
Ste 200
Jacksonville, FL 32216
(904) 725-0601
Nov 21, 2009 | Golden Technologies Companion II Travel...
Scooter will not move
make sure you have put it back in gear, sometimes the freewheel lever is not fully engaged. the light should not blink when the lever is in the drive position.
Sep 11, 2009 | Golden Technologies Companion II
Moving problem
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
Jun 26, 2009 | Golden Technologies Companion II Travel...
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Mobility Scooter - Golden Companion 1
Please make sure you FREEWHELL lever located at the rear is in drive mode, if you can push it, move the level.
Aug 03, 2008 | Transport Schwinn Rechargeable Portable ...
Golden Technologies Companion II Travel Scooter Logo
117 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
