Question about InFocus IN72 Multimedia Projector
SHADOW IN THE BOTTOM RIGHT CORNER . tHE TECH TOLD ME THAT ONE OF THE MIRRORS IS OUT OF ALIGNMENT. cAN THIS BE FIXED?
  • 4,234 Answers
Yes this can be fixed, but not as a DIY project. The adjustments require special test equipment and jigs. This unit requires a professional repair.
Dan
Posted on May 26, 2010
Rca model# hd61lpw163
hi,
while having another problem fixed the tech told us about fixing the shadow in the corner problem. check the tubes. he said when they get hot the glue around the tube melts and causes the problem. he removed the access glue and ours is all better, i hope this works for you too.
Jul 11, 2008 | RCA HD61LPW163 61" Rear Projecection HDTV
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
I have a problem with my ricoh FT3613
As your machine analogue it will suffer greatly from dust build up on the mirrors and this will cause dark copies and shadowing particularly bad on the edges.
Turn the power off. Remove the glass and carefully clean the mirror with a cloth. Do not scratch the mirrors and try not to move the lower mirrors as in some copiers they can cause it to go out of alignment.
It may be other things but this is the most likely and the only one you can fix.
Mar 14, 2008 | Office Equipment & Supplies
Dark bottom half of screen and dark patch in corner
Thanks for the picture - that's a big help.
It looks you have the dreaded light tunnel collapse common to all LG1.gif DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps.
Hope Ya Fix It!
Jan 24, 2008 | LG RU-44SZ51D 44" Rear Projection...
Picture problem
might need to get a tech to align it in what is called service mode
Jan 01, 2008 | Philips 60PP9202 60" Rear Projection...
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Dark spot in bottom right corner of screen
Is this a DLP or a conventional 3 tube projection tv?
Sep 15, 2007 | Hitachi 50V710 50" Rear Projection...
Shadow on upper left corner
A little late and you've probably already solved it or are just living with it or are disgusted with it and have discarded the tv. But, in any event - here we go. The "light tunnel" bends the light toward your screen. At the beginning of that tunnel there is a plastic lens. The lens is secured with four little feet that a part of the lense. The lens is flat on the side closest to the screen. It fits on the end of the light tunnel closest to the light. The lens probably has a burnt spot. Probably the burn is caused by excess heat which is either a result of a fan failure or a one-time situation where the power went off while everything was hot and there was no cool down cycle. Another item to look at is in the light path before that lens. There is a small "window". It's actually a very thin piece of glass (about 1"X1") held in place by a horseshoe shaped clip and one screw. I think that glass has the purpose of keeping heat away from that plastic lens. If that glass is broken I think you'll have a heat "leak" and the plastic lens will continue to get worse.
Jun 30, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
How to fix black shadows appearing on both sides of the screen?
i beleive its electrical problem (horizontal circuit). if u are not inclined with this job just bring it there and besides they will give you warranty for their work.
Jan 14, 2007 | Optoma RD50 Television
JVC AV-56WP30 red "shadow"
The problem called Convergence problem. Unfortunately, some sets have manual convergence boards - which means you can do nothing but replace it and adjust the manual controls on the board itself. But some of the newer ones (Maybe yours) can be accessed through a service mode. So, give it a try and look for a service mode in your set... Good luck!
Jan 02, 2006 | JVC AV-56WP30 56" Rear Projection...
InFocus IN72 Multimedia Projector Logo
116 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
