Question about Vacuums
I need to know how much oil to how much chocolate for the chocolate fountain, lost directions and i need them for tomorrow
  • 652 Answers
2 12 oz chocolate chips
3 un sweetened chocolate squares, chopped
3/4 cup canola oil
1/4 cup kahlua (optional)
Posted on May 26, 2010
How much chocolate is needed for a cookworks chocolate fountain
http://www.koolatron.com/manuals/WTF-43E%20Choc.%20Ftn%20Double%20Tower%20Manual.pdf this is the only thing I could locate, there are reviews on your machine but none told of a limit or amount, they all did say however to add a little oil to the choc as it helps the flow and you cant taste it
May 18, 2011 | Vacuums
Elkay drinking fountain M#erpb28c continuously runs, having problems getting mounting nut back onto bubbler, seems basin should come off for access, however needind a reapir manual or access instructions...
The Elkay fountains are turned on by a solenoid powered valve. There is a rubber grommet in that valve assembly that gets holes in it and then water gets behind it, causing the valve to stick on. To test that it is a solenoid problem, turn the water on and then unplug the power to the fountain--if the water continues to run you have a solenoid problem. You'll need to replace the solenoid and I've detailed how to do it with all the steps and lots of pictures on my blog: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Feb 22, 2011 | Vacuums
Hi. My machine works, but is beginning to sound loud. My husband says it sounds like things are rubbing together and it needs oil. I have lost my manual and don't know where to oil it. Please help.
It is not any oiling but the motor must be making the noise due to a damaged bearing/bush. An oiling might redduce but might not be a solution.
But in the first place we need to open to confirm as the source of noise is the fault itself.
Maybe a reset can solve the issue.
Sep 09, 2010 | Vacuums
Instructions to CFF-986 chocolate fountain doesn't say how much melted chocolate to use. Also, is there a certain kind that is best to use?
It holds up to 3 pounds of melted chocolate, There is no certain brand of chocolate that works best but you will find that the smaller chocalate chips melt better and you will also need to add a little vegetable oil to keep it flowing properly.
Aug 26, 2010 | Vacuums
HELP!!dyson vacuum only 2 years old model DC18 runs but has lost suction on the wand side of the vacuum does anyone have any suggestions for us??
its the ball cradle assembly. There is a little clip that changes the direction of the suction. that clip breaks all the time and causes the internal direction valve to stay in one position. unfortunately dyson doesnt sell these parts separate, you will have to purchase a new cradle assy. let me know if you need a part #
Jan 06, 2010 | Dyson Vacuums
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Eureka canister vacuum model 6865- cleaning
70227 is the part number for the owner manual, but you would have to have it order it. You can call 1-800-282-2886, this is Eureka's customer service, they don't have it in their data base, but maybe they can find something for you.
Mar 10, 2008 | Vacuums
Lost directions to the cleaner.
Hi , check the water level and refill it .
Jan 21, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
42 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
