Question about Margaritaville Frozen Concoction (DM1000) Blender
My margaritaville blender was started without the blender being properly attached to the bottom of the unit. the round rubber piece that has ridges around it got damaged so when the blender is turned on it doesn't function properly. Is there anywhere I can order a replacement rubber part
  • 2 more comments
  • Paul Braam
    Paul Braam Feb 08, 2017
    Dud you find the part mine did the same thing and wore off the kogs also . I need this part!
  • Paul Braam
    Did you find the part mine did the same thing and wore off the kogs also . I need this part!
  • Frankie Fraley
    Frankie Fraley Sep 25, 2017
    I need both couplers
  • Frankie Fraley
    Does some other coupler fit The DM 1000
  • 276 Answers
Posted on May 26, 2010
How do you remove the bottom of the blender?
A inexpensive set of security bits from Harbor Freight contains compatible screwdriver heads. There are actually 4 tamper resistant screws- two are hidden under the rear rubber anti-skid pads.
Jul 23, 2014 | Margaritaville DM1000 Blender
The rubber gears on the base are worn out. need parts to replace
The manufacturer makes Parts & Accessories available through this site:
http://www.margaritavillecargo.com/product.aspx?pid=1377
Parts & Accessories are also available here:
http://www.blenderexpert.com/margaritaville-blender-parts.html
If you do not see the part you require I would recommend you send an inquiry to the manufacturer via their webform:
https://secure.margaritavillecargo.com/ContactUs.aspx
Apr 07, 2011 | Sunbeam Margaritaville Professional...
Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Rubber Gasket
I would reccomend getting one directly from the manufacturer - their number is: 1-877-689-2737
If they don't sell the gasket separately, there are small appliance and hardware stores in some locales that will find the right gasket if you bring the machine in - I would call ahead to make sure.
-Tha Mp3 Doctor (also loves Margaritas)
Sep 08, 2008 | Margaritaville Frozen Concoction (DM1000)...
Blade not turning
the top rubber piece could be worn enough that it is not engaging the pitcher. look at it carefully and see if the "teeth" of the rubber disc on top of the base has not cracked and worn away. a picture of the new one can be seen on the parts websites to compare I spent $10.00 for my replacement but i found them at other sites for $6.00. you will need a very skinny 7mm open ended wrench to get the old one off and it is left handed threads that means clockwise will loosen not tighten the part.i ground down my wrench but an ignition wrench from an auto store will usually be thin enough to reach the flats on the shaft under the rubber disc
Feb 21, 2008 | KitchenAid KSB3 Classic Work Top Blender
Margaritaville Frozen Concoction (DM1000) Blender Logo
935 people viewed this question
Top Margaritaville Blenders Experts
john h
Tom Chichester
Are you a Margaritaville Blender Expert? Answer questions, earn points and help others
