Question about Fisher Paykel EcoSmart GWL15
Went into laundry room and washer was full of clothes and water but had shut off. Computer would not turn on even being unplugged for several minutes. Emptied clothes. Drained water. Removed inner tub and made sure drain was clear (had this problem before). Everything is OK, but machine will not turn on.
  • jandkpauley May 26, 2010
    I emptied all of the water out by hand. The machine wasn't leaking. The drain is clear. I have removed the clothes. It simply stopped working and will not turn back on. None of the lights were flashing I noticed it had stopped, but that was hours after I initially started it. I can't get any lights, any "beeps" or anything out of it. I checked the outlet and it is working fine. My guess is that it was overloaded and automatically shut off. I am wondering if the computer needs to now be reset.
    President:
  • 1,554 Answers
It sounds like the motor controller module is dead. Check power directly on the motor controller module and also check the connections between the dispaly module and the motor controller module.
Posted on May 26, 2010
  • Jahn27
    Jahn27 May 26, 2010
    Leave the machine unplugged for a couple of hours to make sure it resets.
    Brigadier General:
  • 3,917 Answers
It seems that there is some kind of leak at the bottom of the washing machine. Please refer to the article provided bellow to understand how to figure out where the leak is.
http://www.ehow.com/how_2285965_leak-washing-machine.html
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
    Sorry, I should have been more clear. There wasn't any water leaking out. I emptied the water out of the tub using a bucket.
Amana top load washer overfills with hot water and wont stop unless you shut supply off. NTW5400TQ1
Okay you say only hot water if you unplug does water still come in if so bad inlet valve if it does it on both then the pressure switch is bad or there is a hole in the tube that goes from tub to pressure switch
Feb 17, 2015 | Amana NTW5400TQ Top Load Washer
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
Water sensor not working. Started a load of Laundry and the water did not shut off therefore flooding my whole Laundry room. How can I fix this myself?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug or turn off circuit breaker ,if the water continues to fill, that valve is sticking,it is what to replaced
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps
Gene
Jul 31, 2011 | GE Spacemaker Washer and Dryer Electric...
I have a HE3 and I would like to know why it had water in it this morning when I went to put laundry in it?
The first possibility is the water valve in the machine is not sealing and it dripped water through the valve into the machine since you last used it.(there are four solenoids on a mixing valve) Something may have lodged, valve may be going, may go away, may get worse, flood laundry room in rare cases.(suggest turning off the hot and cold water house lines between use at the shutoff where washer is connected)
Second is the pump did not pump out the water, but the clothes would not have spun out, not very likely by your description of problem .
Lastly low water pressure on your house line may have affected the valve shutting off, but this is also rare, again, shut off water to unit between use at house supply lines.(hot and cold)
good luck
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Water is full in washer and wont drain or anything??
mostly drain problem or spin problem. It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 08, 2009 | Washing Machines
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
60 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
