Question about Peg Perego John Deere Gator HPX Ride on Toy
Gator works on and off
It seems like there is an electronic issue with my daughter's peg pergo gator. Simply put sometimes it works when she presses the accel pedal and sometimes it doesn't. It seems like the motors are fine but there must be a bad switch or wire. I hate to replace all the electronic parts if it isn't necessary. Any suggestions where to start?
Thanks,
Andrew
    An expert whose answer gotĀ voted for 100 times.
    Habit-Forming:
  • 156 Answers
I replaced the shifter with the peg perego upgraded shifter and that seemed to fix the problem, but you can contact the repair department at
http://www.mypegperegoparts.com/ and they will be able to help you
hope this helps
Posted on Jun 08, 2010
Peg pergo John Deere Gator goes for about 2 seconds then stops suddenly
it almost sounds like a thermal fuse, but these don't have a thermal fuse, so id say it might be a bad shifter switch
Dec 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
I want to test motors on pergo gator can i hook up reg 12 volt lawn battery to test that they spin or can i test charger
no don't hook it up to regualr 12 volt battery, first check the voltage of the peg perego battery and make sure that its putting out 12 volts, then you can use jumper wires and connect to the motors with the peg perego battery and verify that they work
Jun 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
Have a PEG Pergo Gator and when the gas peddle is pressed makes a high pitched whine sound from near the wheels.
bad gear box, check to see which wheel it is coming from and then let me know if you need me to order you one
Jun 11, 2011 | Peg Perego John Deere Gator HPX Ride on...
Put a new charged battery in john deere and nothing happened ? peg-pergo 12-volt
It is most likely that you have a bad shifter switch, located under the shift handle. They can go out and do go out on people often. You can call their Tech Support which is excellent and will also walk you through if needed, you can also order the parts through them. 1-800-728-2108 or you can go to http://www.mypegperegoparts.com/asgi0115nyr.html to find the part
Mar 03, 2011 | Peg Perego John Deere Gator HPX Ride on...
Help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Mar 17, 2010 | Peg Perego John Deere Gator HPX Ride on...
Changing the peg pergo battery for an atv battery
There is no specific wire kit to change it over. If the amps or volts are changed in anyway it can cause serious damage to the vehicle and the child. The Peg Perego Batteries usually last about 3 to 5 years if taken care of. You can contact the repair guys at http://www.shopjandl.com/ I had a problem with my battery and they gave me tips on how to make it last longer
Jun 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Mar 24, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
151 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
