Question about Samsung (MP0804H) 80 GB Hard Drive
Not showen in computer
When the hard disk is attached in computer,only 4GB of hard disk is showen.
  • 22 Answers
You need to properly re partition the hard drive
try c: max size
Posted on May 26, 2010
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
Is there a way to erase the data on mydane-elec 4gb
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jun 27, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My HP 4GB pen drive seems to be malfunctioned, it shows a message while attaching it, that "the device attached to the computer is malfunctioned, windows cannot reconize this device" What...
Trying attaching to a different USB port or different computer. If still the problem is not solved try formatting the USB PEN drive using HP USB Disk Storage Format Tool. If still not ok, then may be its a hardware issue with the PEN drive.
If its under warranty, try for a replacement.
Apr 04, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I plugin my 4gb DaneElect , but mt computer doesnot recognizes the device
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
Feb 25, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Cannot access drive PNY Swing attache 4gb. Drivers installed and is recognized as a hard drive in the device manager Windows 7 64 bit home premium
you may have a drive letter conflict, go to disk managment (right click computer / manage / disk managment)
right click on the pen drive and change the drive letter
Sep 30, 2010 | Computers & Internet
4 gb pendrive not detect
Your computer probably requires a special driver for this large type memory stick.
MANY older computers do. If the device came with a driver disk, then try to install a driver.
OFTEN it seems that there is a point at 2GB that older and cannot read above without special software driver. This also happens with amny devices like cameras, etc.
Jan 19, 2010 | Kingston 4GB Secure Digital High Capacity...
I have dell inspiron 1525 c2d with 250gb hard disk
tru following steps
1) plug in usb device
2) change your boot option to cd from hard disk
3) insert installation disk in cd drive.
4) follow the steps.
5)finalize instalation.
Enjoy !!!
Mar 18, 2009 | Microsoft Windows 98 for PC
Dane-elec 4GB usb insert desk problem
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Nov 22, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
My 4gb kingston pendrive is not recognize by any computer
Hello
For Solving your problem do the following
1. Check that the USB is connected properly to the mother board
2. USB 2.0 Drivers are loaded
3. See that the Pendrive is properly connected
Let me know that your problem is solved and rate me as Fixya!
Sep 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Installing 2 hard drive
if ur hard drive is IDE port then
attach the 1st end of ide cable to the motherboard and second end of ide cable {IDE1}to the hard disk {make this hard disk MASTER by change the jumper settings }
attach the second hard disk to ide cable {IDE 2} make this hard disk SLAVE by remove the jumper from hdd
Mar 20, 2008 | Computers & Internet
Samsung (MP0804H) 80 GB Hard Drive Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
