Question about Bosch & Tankless LP Hot Water Heater
We have an Omega Tankless Water heater,OMEGA COMFORT OME 14-PV that is showing a E6 code. We unplugged it and that did not help. We are on propane if that makes a difference. This unit is approximately two years old. It has never worked properly at keeping the water temps the same for both the kitchen and the two baths, but has been liveable until now and it wont work at all.
  • 25 Answers
SOURCE: Bosch 125 Tankless Water Heater - Water not hot enough
Sounds more like the venturi in the watervalve of the tankless water heater is clogged. I would recommed rebuilding it and paying close attention to properly relubing the pushrod and cleaning the venturi.
Posted on Jan 19, 2009
  • 234 Answers
SOURCE: bosch13 gas tankless water heater no spark
Well if you don't have no spark,have you check to see if you got power?If you do have power ,the turn the water on to see if it will spark.If not the Check to see if the fuses are blown insde the panel.Most of them have fuses on the power coming in.If got all of that then you proablly wil have to replace the igniter board.
Posted on Mar 19, 2009
mrhotandcold
  • 248 Answers
SOURCE: we have a 3 year old Bosch GWH 425 HN tankless LP
suggest you complain to Borch sometimes lemons get through best of luck
Posted on Oct 30, 2009
mrhotandcold
  • 248 Answers
SOURCE: I unfortunately own a Omega 2000 Group tankless
check semsor and leads best of luck
Posted on Dec 03, 2009
ftw1952
  • 10319 Answers
SOURCE: heater will not ignite
The sensor that allows the pilot to ignite is at fault
replace the probe that points at the pilot light which is the sensor
Posted on Apr 04, 2010
Omega comfort
Fan is fauilty need to replace as it purges be for it will light up
Sep 15, 2013 | Water Heaters
Bosch aquastar wont get hot
1) If tankless is not showing error code, the problem might be single-handled faucet cartridge:
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
2) Catch up on maintenance, such as cleaning combustion parts, have gas pressure checked, etc.
Feb 20, 2013 | Bosch AquaStar Natural Gas Tankless Water...
My Boch 24ES Highflow Hotwater is showing Code 14 and only runs for i minute then shuts off
Code 14.
What water heater do you have?
Question posted under tankless Bosch, but these error codes start with a letter.
Rheem/Richmond etc Tankless has error code 14
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Call tankless service technician.
Ask technician how much it costs to have recommended yearly service.
Or install whole new tank-type gas water heater yourself for $350 from local box store, and avoid the entire headache, then sell tankless online for parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 09, 2012 | Water Heaters
Code 11 all the time have had it cleaned still getting code it is on propane had propane tank checked pressure ok
Before calling service technician, open following links for troubleshooting resources including Rheem phone, chat, error codes, general maintenance pdf, and generic service manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Tankless-service-manual.pdf
Error codes are considered start point for troubleshooting.
Error 11 is 'no ignition' or 'no gas'
You have checked gas and pressure, and had parts cleaned.
Other causes can include: igniter wiring, bad igniter, loose wire on gas solenoid, bad solenoid, improper grounding.
Aug 12, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Code 73 on a noritz tankless propane water heater
73 code is a circuit board error. It typically occurs if you connect or disconnect anything in the heater with power on. Try disconnecting electricity for 20 seconds to reset the unit. If the problem continues, you may need to replace your circuit board.
Apr 08, 2011 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
Rheem tankless propane hot water heater error code C7. Cant get hot water. It keeps shutting off and then once turned back on wont work and gives the C7 code. What does it mean?
Use following link for Rheem tankless troubleshoot: http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
I believe error code C7 is same as error code 76
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Rheem Tankless Hot Water Heater...
Our tankless water heater is not turning on, but
blockage at pilot ,gas valve faulty ,if you have a changeover valve fault could be there
Oct 07, 2009 | Rinnai Webstone The isolator EXP tankless...
E2 is the overtemp code. Unfortunately, the Omega line does poorly with single-handle faucets. Don't bother George Sararu, he just bought a container of these water heaters and knows nothing about plumbing. There will be no repair parts you will need. Either toss it now and get a tankless from a local dealer, or wait until your Omega unit is totally useless, then go with a local guy. George conned a lot of people - including me. I own 2 side-by-side in the utility room and figure one more year until they are junk.
Since I'm on a well, they have to be seasonally adjusted to compensate for groundwater temps. Big pain, should have bought Rinnai.
Sep 03, 2009 | Bosch & Tankless LP Hot Water Heater
Raypac HL 2 error code. How do I reset
unplug the unit for 1 to 2 minutes you can usally hear it click off when it is reset,
Jun 15, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Bosch & Tankless LP Hot Water Heater  Logo
157 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
