Question about Thetford Norcold RV Cooler/Freezer
The air conditioner and refrigerator will not come on like they have no power and we have had it checked
  • 6,831 Answers
Hello
Have the people who had a look at the device had a good look at the transformer on the circuit board at the power inlet?
Also, have they checked the fuse of the device? This advice may sound stupid, but in order for me to diagnose the problem, we need to start at the most basic problem areas.
Please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Posted on May 26, 2010
  • jimwarney Aug 24, 2010
    My camper did the same thing and come to find out it was the power converter cost around 200.00 and that was me doing all the rewiring myself! Just to let you know!
Why won't the air conditioner blow air?
The very first thing you need to do is to check for fuses or say faulty fuse. Secondly check fan which starts along with air conditioner, it might be manually switched off or the fan may have been clogged. Also reason can be lack of refrigerant - charge your air conditioner with refrigerant. Last thing you need to check is cooling coil - the cooling coil may freeze if there is no refrigerant in the system.
Jun 11, 2013 | Ford Explorer Cars & Trucks
How do I add freon to Haier air conditioner?
Windows air conditioners do not come with service ports for checking or adding refrigerant.They are considered throw away items and you just replace them if they leak refrigerant.
Jun 26, 2011 | Haier ESA3063 Air Conditioner
Haier air conditioner will not kick on to air conditioner mode, only the fan runs, but does not cool like air conditioner should cool, just blows as a fan.
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
May 29, 2011 | Haier HWR08XC7 Air Conditioner
Air conditioner stopped working, nothing works, breaker is on, power to air conditioner is good, It was working just fine and then every thing stopped. All the other electrical things are working just...
May 26, 2011 | Dometic Rooftop RV Air Conditioner
My portable air conditioner is running, it seems like the compressor comes on, but the temp in the room does not decline and the air from the air conditioner is not cool. I purchased this air conditioner...
Apr 13, 2011 | Maytag M6P09S2B Portable Air Conditioner
Whirlpool ACQ128 Air Conditioner was working then it turned off and won't power back on
Feb 06, 2011 | Whirlpool ACQ128 Air Conditioner
MY frigidaire Air Conditioner model number: FAC107P1A2 has suddenly stopped blowing cool air. Check Filter light comes on but filter clean. Press Check Filter light button and blows out cool air for...
Aug 24, 2010 | Frigidaire FAC107P1A Wall/Window Air...
WHAT IS ERROR CODE F96 ON A PANASONIC INVERTER AIR CONDITIONER - MODEL CS-E28HKR ?
F-96. Over heating protection. to solve it-------Check for • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor)
Nov 21, 2009 | Toyotomi TID-1800HP Air Conditioner
Friedrich air conditioner stopped running. I was trying to find what the air conditioner was causing to vibrate near the unit. I moved the power cord while the air conditioner was running, pushed the...
This is very possible. Whenever a compressor is unplugged it should rest for about 5 minutes before turning it back on. This is because the refrigerant needs to balance. Otherwise a large amount of amperage may be required to start the compressor as it tries to compress to much refrigerant at one time. I would first check the main breaker for that outlet before jumping to any conclusions. Then let it cool completely before trying again. If this still does not work, you may need to bring it to a service center.
Jun 30, 2008 | Haier hwr10xc6 Air Conditioner
Ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Mar 26, 2008 | Hunter 30124 Air Conditioner
Thetford Norcold RV Cooler/Freezer Logo
75 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
