Question about Philips MX5100VR System
Audio protect off - Philips MX5100VR System
    President:
  • 1,099 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} All of a sudden it showed PROTECT nomatter how many times you turned it on and off.
Checking the speaker cabling for any shortcuts and eventually disconnecting all cables did not solve the problem.
So you opened the case and disconnected the pcb where the speaker outputconnectors are soldered to. This small board also had the speaker on/off relais (light blue). you should disconnected the main connector (white) from the main pcb and turned the amplifier on again: problem of 'protect; will be solved ....
So you should checked for short cuts in the pcb, removed the dust and made sure the wires (red black black white) were not touching eachother; the isolation can be damaged by the internal heat and the wires are routed so that they touch internal components.
After reconnecting the main connector the receiver should be okay...
Posted on May 26, 2010
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
Tip
Cracking DRM from Video and Audio Files
You may have bought lots of videos or audio files from online shop , these files may be DRM-protected, so that you couldn't play them on all popular digital media player like iPod, Creative ZEN, Zune, iPhone, PSP, Archos and other MP3 players.
With a legal drm removal software, it iseasy to crack drm protection from videos and audio files. Daniusoft DRMConverter is such a professional software, which provide a legal solution for
drmremoval crackandsharing DRM video and audio files. It is specially designed for audio and videofans. It removes DRM protection for both protected audio and video files withhigh quality and output your DRM video and audio files into plain ones that canbe played on all popular digital media player. Following is step by step guidefor cracking drm:First step is to launch the installed thisdrm removal software andclick "Add.." to upload files for DRM cracks. The second step isunder "Video files to:" or "Audio files to:" item, clickthe drop-down button and select a common video or audio format for DRM removalcrack. The last step is to start conversion, after doing the steps above, click"Start" button in the bottom right of the DRM removal crack softwareprogram.
After cracking drm protection, audio andvideo fans enjoy them on iPod, Creative ZEN, Zune, iPhone, PSP, Archos andother MP3 players easily.
on Jun 09, 2011 | Computers & Internet
Jvc home component mx-kb30 protect mode on
First check that the speaker wires are not shorting, if okay! the problem is in the audio output stage of the receiver, the protect mode comes on if a load is detected.
Apr 25, 2012 | JVC MX-KB30 300W Mini Home Audio System...
SHARP BA200 Protect Mode?
Check the speaker wires for shorts, if okay! the audio output ic's are loading the circuits causing the protect mode to engauge, only option replacement of the above mentioned parts.
Apr 21, 2012 | Sharp CD-BA200 CD Shelf System
Can anyone please help me with my superstar red 3900 has i have changed the audio chip and protection diode and i have still got no recieve what could the problem be thanks
No RX or No Audio?
Could be blown protection diodes or if no audio a faulty capacitor close to the audio chip!
The protection diodes can blow if you were close by someone with a high power transmitter, then the diodes would blow kinda like a fuse to protect the rig, result no RX symptom!
Replacing the diodes will cure that problem, located close to the rear of the rig.
Sep 06, 2011 | Superstar SS-3900EGHPA CB Radio
How do i get my Kole audio qx4-720 amp out of protection mode
be sure the master volume is in minimum some amplifier has protect circuit when the volume exceed the maximum sound level to protect circuits from damage. try to disconnect speakers maybe one of them are shorted already
Feb 02, 2011 | Kole audio QX4720 Car Audio Amplifier
I have a ma audio hk-602sx and my protect light wont go off and somthing is clicking inside and as it clicks the protect light blinks.
Disconnect the speakers and then try it again...there may be a shorted speaker or wire if the amp comes out of protect after you disconnect the wires...if the amp stays in protect after you disconnect the wires then there is a problem inside the amp with the circuitry and it will need to get serviced by an electronic tech
Jan 23, 2011 | MA Audio HK602SX Car Audio Amplifier
The protection light keeps coming on on my ample audio a 410x amp it was working and now its not whats the problem
Most of the time. If the protection light is on that means your protected. Not that there is something wrong. So if it is working then your fine.
Mar 02, 2010 | Ample Audio A 410X Car Audio Amplifier
Legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
Mar 01, 2010 | Legacy Audio American Legacy II LA590 Car...
How do I take my AG-8520 Audio/Video Receiver out of Protect Mode
go to the help and support section of your laptop, and type in protect mode. This should pop up a list of options for you to take it out of protect mode.
Nov 13, 2008 | Acer Aspire 3690-2196 Notebook
Philips MX5100VR System Logo
144 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
