Question about Sony KDL-32EX400 32 in. HD-Ready LCD TV
Functional Noise Hi , I have a"Sony KDL32EX400 32" brand new, and when switched on it make a noisy sound like beeppppp for the top right back corner,and if you speak down the volume to 10 you can still ear it. Is that normal?
  • 178 Answers
Not normal, top right back corner have inverter board and power supply board. It may be the transformer making noise. you are better to exchange it.
Posted on May 26, 2010
Testimonial: "thanks"
  • Shukai Fung
    Shukai Fung Jun 04, 2010
    You are welcome!
The fan is making a "scratching" noise.
Hi steffmarin...
The scratching noise is one of two problems.
1.noisy fan bearings, cannot be lubricated, must be replaced (big job), or replace fan....
2. Plastic/rubber bearing up near the ceiling...the fan will be connected to it.
Sometimes when they get dry they get noisy.
You can spray the plastic/rubber bearing with a little WD-40 and it will hold the noise quite for a while...be sure to "wiggle" the fan around after spraying to distribute the WD-40) evenly.
If your noise problem is this then problem solved.
Please take time to rate me
Jul 22, 2011 | Hampton Bay 52 In. Ceiling Fan, San Tropez
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Noisy AC fan in 240GL 1986 model sedan. Fan make a terrible noise when the AC switch is turned on. After about two minutes the noise disipate after the fan swich is put onto maximum power. However, the...
Hi; Sounds like a bearring is getting dry and sweaking. Sometimes You can acess the motor from under the hood very easy. If not please let a person with auto skills attempt this Weather its a friend or a professional...alpharome416
Feb 22, 2010 | Heating & Cooling
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
HP LaserJet 3055 not powering on
Possible noisy laser unit or fan. Most likely the laser unit.
However,
You can pull the fuser out by pulling the rear door ALL THE WAY DOWN and remove 2 large screws and pull the rear cover off, then the the left and right small covers, the plastic guide on the bottom and 2 fuser screws. Be careful with the small wires on the right side.
You have to remove all covers to get to fan and laser which is a triangular shaped black box under the top cover.
Jun 10, 2009 | HP LaserJet 3055 Flatbed All-in-One...
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Hobart A120
Yes it does sound like lubrication. And if they start out noisy, they tend to stay noisy. There is inspection dust caps under the top cover.
Apr 25, 2008 | Food Mixers
Noise/Not Playing Games
The main circuit board may have problems and will need manual expert repair. take it to a repair shop. Good luck.
Sep 12, 2007 | Sony PlayStation 2 Slimline Console
Sony KDL-32EX400 32 in. HD-Ready LCD TV Logo
173 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
