Question about Black & Decker Black and Decker Mm575 18" Mulching Lawn Hog Electric Lawn Mower
Cannot tighten blad for 18" Electric B&D Mulching Mower
Replacement blade and bolt spins roter and will not tighten to secure blade into place.
    President:
  • 3,433 Answers
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
Posted on May 26, 2010
How to tighten blade
if the blade is unbalanced it will not stay tight and should be replaced then with a block of wood to hold the blade from turning tighten the replacement blade
Jun 10, 2012 | Black & Decker 19" Electric Lawnhog...
How do i tighten the blade on a black and decker MM575-18
Hi Kevin,
User a pair of channel-locks to grab the square spacer below the nut. Then tighten down the nut using wrench.
May 07, 2012 | Black & Decker Lawn Hog 18-Inch 12 Amp...
How do i remove the blade?
there should be a bolt have someone lock the blades and un turn the bolt
Aug 16, 2011 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Shaft turns when I try to tighten the mower blade
Remove the bolt, washer and blade. Use a wire brush or sandpaper to clean the end of the shaft and the blade where they make contact. Clean both sides of the washer. Clean the underside of the bolt head and the bolt threads (with a wire brush). Put just a little oil on the bolt threads and on the underside of the bolt head. Reassemble.
Jun 17, 2010 | Black & Decker 19" Electric Lawnhog...
Cannot get the blade off even following the manual's directions. Nut is slowly spinning under pressure with the square washer and blade is held in place with 2x4. Is it seized?
Try this
Apply a good dose of Liquid Wrench and tap the bolt head sharply several times
Wait 2 hours and then attempt to TIGHTEN it just a tiny bit
Remember Righty Tighty Lefty Losey
Now try to take it off If you have an 1/2" air impact wrench it will make the job much easier
Mar 31, 2010 | Black & Decker 19" Electric Lawnhog...
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric mower will not work
the shear pin has broke on the drive shaft put a new one in.
Apr 28, 2009 | Black & Decker 19" Electric Lawnhog...
Craftsman Electric Mulching Mower 37051
i had the same problem i tried to bend the lift arm to the left put that didnt last /then try drilling 1/4 holes at diferent heights and put a 1/4 screw to hold it
Oct 04, 2008 | Electric Lawn Mower
Blade assembly does not tighten
check out toolpartsdirect.com for parts diagram.
Jun 18, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker Black and Decker Mm575 18" Mulching Lawn Hog Electric Lawn Mower Logo
523 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
