Question about Xerox Phaser 8200 Laser Printer
HELP! What does this mean?
Xerox Phaser 8200 colour printer
Error: 15.004.45:24333
    President:
  • 2,072 Answers
The drum is not warming up.
Most likely, about a 95 percent chance is the halogen lamps
used to heat the lamp are not comming on. Most likely one has just failed.
They are a bit time consuming to replace, and you have to take a few items off of the printer to access and replace them.
They are standard, in the U.S, 120 volt , 150 watt halogen lamps.
What you want to do is, turn the printer off first, then turn the lights off in the room. Turn the printer back on, and look through the sloted fan opening on the right side of the printer. See if you see an incadescent type glow in the machine. Give it a minute or two to come on. I suspect you will not see anything because of a failed lamp.
But that is most likely the issue.
Posted on Apr 07, 2008
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200 printer error 15.004.45. How do I
If this is your first rodeo, contact www.inktechnologies.com. They can walk you through it and provide the parts.
Jun 28, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
My Phaser printer says it has a printing error # 07,002.44:6717 - what does this mean?
Try plugging error number into Google search including printer name and model.
Jun 11, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Error xerox Phaser 8200 15004,45:12318
Hi erniec420:
Hope that this helps.
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850 and 860 have a pre-adjusted head.
Apr 03, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
55 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
