Question about Jenn-Air Refrigerators
Compactor is stuck in the closed position. It will run the cycle, but won't open. Jennair model JQTC4061 serial number 900345XX
SOURCE: g.e. profile compactor gcg1540f0ss
the nut on the ram drive fell off for me and the chain fell off and then broke the grear drive. At 72$ each for the two ruined gears I don't know if I should try to repair it or get a new one.
ERRR
Posted on Apr 24, 2008
SOURCE: GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Posted on Dec 25, 2008
SOURCE: Compactor ram stuck partially down & door open
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Posted on Feb 21, 2010
  • 1218 Answers
SOURCE: amana model #tr25vl and serial
Good day,
One of 2 causes. The valve sticks in the open position and won't close, or the ice maker electrical circuit tells it to keep filling.
99% of the time it is a defective water valve located on the back bottom of the machine. Changing it is basically a nuts and bolts job. Fairly easy.
If however the problem resurfaces you would need to replace the ice maker but since it is common practice to install a new valve when installing a new ice maker, it's really no loss.
Posted on Sep 15, 2010
TheMobilian
  • 8220 Answers
SOURCE: my trash compactor a ge zcg3500 approx. 3 years
When the ram reaches the end of its downward movement, the motor stalls. When the motor stalls, it
causes the motor centrifugal switch to change position(s), completing a circuit through the CCW motor
windings (ram up direction). This circuit is set up through the top limit/directional switch, which is
activated by the ram. At this point, the motor reverses direction and the ram moves in the upward
direction.
Posted on Oct 18, 2010
Trash Compactor Thumps
I would guess there is a limit switch that tells the machine to stop once the compactor has retracted.
May 04, 2013 | Kitchen Appliances - Others
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
JennAir Trash compactor stopped compacting. What could have caused this problem.
Here's a link to Jenn air website: http://jennair.com/appliances/details/TC607X
You can Chat with a live customer support personnel
Jul 06, 2011 | GE Stainless Steel Built In Trash...
Kitchenaid trash compactor bought in 2000; no model/serial number found. Compactor was stuck in partial down position; worked the drawer out and found cotton fibers wadded/stuck at top of the up/down...
at the top, above the ram, there are two switches. One is the reversing switch (should have 4 wires), the other is the stop switch (2 wires). I suspect that the switch arm is bent, due to what you just described, and fails to activate the switch to stop the motor when the ram is at the top position.
May 24, 2011 | KitchenAid Microwave Ovens
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. Now, I can't even open...
We had the very same problem. Pull the compactor out and unplug the unit. Lay it on its side and remove the bottom. This will expose the chain and gears. On our unit, the plastic sprocket was broken. This part turns the chain to make the ram go up and down. When I called about a local location to buy a new part, I was given 1-800-688-9900 to phone for help. Tell the automated service you want "parts" and you will get an operator. I described the part and she said that is was no longer made in plastic -- it's now metal. The part number she gave me was #675370. I could've ordered the part through them and would receive it in 3 business days. With our zip code, she was able to give me two locations in our area to get the part. One place had the plastic part -- no thanks. The other place was able to get the part in the next day. Hope this helps more than solutions 1-3.
Jan 23, 2010 | Microwave Ovens
My KitchenAid trash compactor model KUCP021RBL1: cycle does't end
Most likely the motorwindings have been overheated after staying to long time in down position and trying to get up.
If there is a Emerson motor in your compactor than you will not find anything wrong most likely it is the winding of the motor, we have had this two times, changed the motor and the problem is solved.
Kind regards,
Paul
Netherlands
Dec 30, 2008 | KitchenAid P Series Trash Compactor -...
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Stuck Trash Compactor
I can't get to the rear of the compactor. How do I get the front off to get to the rest of it?
Mar 14, 2008 | Dishwashers
Refrigerators Logo
57 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
