Question about Craftsman Professional 1/4 Hp Submersible Utility Pump
Water pump keeps on running my mastercraft jet pump keeps on ruunning/ will not shut off i have a mastecraft jet pump 3/4 hp aprox 5 years old/ pumps ok however not shut off, i must turn off from switch it sits @ 2 ft above water level, pumf fto aprx 50 ft tank is located aprox 40 ft away from pump, @ about 5 ft above pump. press siwtch is new, foot valve new, tank press set to proper specs [2 lbs below switch settings] can anyone help?? pls reply memedede@rogers.com
    President:
  • 3,433 Answers
YOU NEED A FLOAT SWItch to have the pump work unattended. I have two new switches and no use for them, Where are you?
Posted on May 26, 2010
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
In house well water pump goes off and comes on vert fast when water is still running.Type Mastercraft 3/4 hp.
Is there a surge or reservoir tank in the system?
Or the pressure switch may have to be adjusted.
Write back with more information.
Gary
Aug 25, 2011 | ADVANTAGE Waterway Spa Pump 3/4 HP 115v
Have an Onga JJ400 jet water pump several years old, pump is working but delivering poor water flow
Is the pump building pressure and shutting off? If the pump keeps running but not building pressure than there is most likely a problem with the well (low volume). Also check for a water logged bladder tank.
RJ
Jun 29, 2011 | Plumbing
1/3 hp shallow well jet pump (mastercraft brand). After power outage i have been having problems with pump. It will run continuously without building up enough pressure to cut out. It wil build up to about...
I don't think the power shortage had anything to do with the pump, I think it is the impeller or a gasket, or both. It is hard to say, a pump like that should **** dry and pull water right in.If you put your hand over the end of the pipe, it should make a mark like an octopus on your hand. I would take off the impeller, look for trouble, and replace 3 or 4 parts in there , you should have water. Hope this helps.
Sep 24, 2010 | Plumbing
I got 1 year old flotec 3/4 hp pump and it take
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Sep 05, 2009 | Flotec Plumbing
Pump will not come up to pressure and turn off!
With no leaks in line and assuming the jet is not embedded in debris at bottom of well, try priming the pump again and getting all the air out.
Jul 05, 2009 | Plumbing
New 1/2 hp jet pump with tank not working
Your hose size is to small. Use a 2in black plastic line out to the lake. Inspect your foot valve, and
take your pump apart to see if you may have a pebble stuck in it, and remove the inner workings
and clean. Contaminates build up inside and need to be flushed out. Remember to replace the
gasket. Tighten all your hose clamps. Once your ready to start, spray shaving cream on your
fittings to see if your sucking air. I've been through it all and my pump works fine.
Chuck
May 03, 2009 | Plumbing
Soap stays on dishes, pump a little noisy Dishwasher is 5 years old
first thing to check for is your fine srtrainer remove it clean it verry well because lint stick inside the edge of the filter causing blockage of amount of water to be pumped out neck thing to check for is the amount of water that comes in to the machine start the machine listen for the first fill to complete open the door there shoud be aprox 1inc of water in the macine if not its possible that the drain valve have something stuck inside causin to loose water to see if its your drain vale when you have check the amount of wate reclose the door let the pump run for a min then reopen the door if you have less water check your drain valve or your check valve normally blue or white aprox 3"long inbetween two hoses thanks from gilles
Mar 15, 2009 | KitchenAid 24 in. KUDS01ILWH Built-in...
Craftsman Professional 1/4 Hp Submersible Utility Pump Logo
856 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
