With a Ruud air conditioner, it will run for 15 minutes, then it will shut off. If I push the test button, it will usually start back up again and run for 15 minutes before shutting off again. When this doesn't work, resetting all of the breaker switches with the thermostat off, then turning the thermostat on, and pressing the test button will run the air conditioner for 15 more minutes before shutting off again.
    President:
  • 1,902 Answers
If the air is still flowing but gets hot, I would suspect a control relay to the compressor. Is the compressor still kicking on after that 15 minutes?
If the compressor is still running after the 15 minutes then you are low on freon and the compressor is heating up causing the system to have to be reset
If the air flow is blocked, I would suspect that the accumulator is "freezing up" from the condensation on it and blocking the flow.
the other thing that you can check on is the thermostat and make sure that it is working correctly
Posted on May 26, 2010
  • joshuaekholm May 26, 2010
    There is a code, d5, that is constantly shown throughout. There is no diagnosis for this code in the manual.
    The compressor is not running after the 15 minutes, the signal light from the thermostat appears to go out, then come back on, but the compressor and fan do not kick back on. At this point, if I press the 'test' button, the fan and compressor will start to run for another 15 minutes.
    There is no block in the air flow, and the level of freeon has been checked by a local ac tech.
    This unit was installed last fall, 1 month before we bought the house, and the home inspection is the only time before this week that we have attempted to run it, and of course it turned on at that time for a minute or 2.
  • Jeremy Reddick
    Jeremy Reddick May 26, 2010
    D5 error code is the control board. So that means that the control board will need to be replaced. What is happening is that the control board is not sending the proper amount of current to the unit for it to stay running. Also it is malfunction the thermostat so that the unit shuts itself off. Replacing the control board is very easy if you do it yourself and can also be done by ordering it online. You can google search your model number and name of the unit and add in there replacement parts. This should solve all of your issues. Please rate.
Ruud will not turn on
check breakers, check 24 volt transformer, check thermostat sometime the contacts on stat will not make proper contact. take front off and clean with contact cleaner spray let dry for a few minutes before turning back on.
May 03, 2014 | Ruud UBHC Air Conditioner
Ruud furnace 2 blinking green light
The ventpipe heat limit, fan limit, and chamber limits are only a few of the safeties that turn a furnace off when something is getting too hot. I recommend a qualified technician have a look at it.
Nov 28, 2013 | Heating & Cooling
Ruud furnace troubleshooting
check that elements are intact and getting voltage
Nov 14, 2013 | Heating & Cooling
My Ruud heat pump fan stops after running a minute. It is 10 degrees out now and defrost mode seems to work fine. It makes a humming sound when the fan gets stuck. Sometimes if I take a ruler to it, it...
The capacitor for the fan motor is bad...replace the capacitor and you'll be good to go...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Jan 23, 2011 | Ruud UBHC Air Conditioner
Outside fan not working
Replace the fan motor capacitor and try again.
Jul 05, 2009 | Ruud Central System Air Conditioner
Ruud achiever 90 plus gas furnace
The door, you mean the metal cover on the front? if you have the door off and push the safety switch in with your hand everything works fine? I need more info here, but if what I said is right, then the "door" isn't making good contact with the switch.
Mar 05, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
