Tv wont turn on. when power button is pressed there is a slight click coming from back of tv.
  • 11,896 Answers
That would be a faulty power supply. That is the box that the is attached to the power plug-in cord.
Posted on May 26, 2010
  • 6 more comments
  • whitworth_da May 26, 2010
    thats what I first thought. but there is no power supply per say. i know sounds weird but the power cord just plugs into the circuit board. any suggestions
  • Nate Stansfield
    Nate Stansfield May 26, 2010
    Some sets are made like this. The board has capacitors on them. Do look for any swelled up capacitors. (they are the round metal canister type components.) Sometimes another indication would be burn marks on the circuit board as well. This is called the power board. Some people purchase analog meters and test the components on the board for faulty ones, and then replace it or them. Others end up replacing the entire power board.
    k how would I test them. I will look in the mean time. I am capable of soldering a capacitor if need be. I just dont know how to test. thanks
  • Nate Stansfield
    You can either use an analog meter or an multi-tester. Each capacitor has it's own rating stamped on it. The numbers on the tester must match the printed rating on the component you are testing.
    I looked on both sides of the board and I see no signs of burn or bulging. how would I look up for a new power board. its a pretty big board about a foot square with many different components
  • Nate Stansfield
    partstore.com and your tv name and model
    I found it but only says 50.95. I want to see a picture to verify it is the one. if it were a power supply i would say no big deal but with a board like I see with multiple accessories I am concerned. any ideas.
  • Nate Stansfield
    You can either get a analog meter or multi-tester and test the components or replace the entire board. If you don't have a metal box that is attached to the power cable or next to it, then there is no power supply just a power board.
My JVC TV wont turn on, the blue LD at the front of the TV comes on, when i press the power button the blue LED goes off and i hear a click on the TV but it wont turn on.
Look at the power supply board, look for capacitors ( look like black or brown cans) that have their silver tops bulging. There is a cross on the top designed to open in a failure so the capacitor doesn't pop. Even if the top is still closed, the slightest bulge indicates a failure. Unsolder all bulging capacitors and replace with same spec. For instance, in a bad Samsung there are 4 1000mf 25v 105C rated caps that always go bad, same symptoms. The caps are about $3-4/pc in USA.
Dec 04, 2014 | JVC LT-40X667 40 in. LCD Television
87virago1100cc wont kick over seems like a relay or switch cause it wont even click
Do any lights come on when the key is turned? Are you you sure there is power from the battery? If yes then what happens when the start button is pressed? Do the lights dim at all? Even without a click noise if the button is supplying power to the solinoid the oil check/dummy lights should dim slightly. If no dimming but the lights are on when the key is turned, start by checking the starter button, if there is no power there trace your way back to the battery with a voltmeter until you find where the power stops.
Mar 23, 2012 | 1999 Yamaha XVS 1100 Dragstar
Samsung tv wont turn back on
you have a majoe problem.you have blown out a component in the power supply.have a tech repair your set.good luck.to make sure plug out the tv and let it stand for about 10- mins plug it in back there after and see what it does if it does not comes on then it is time to call in the repair man.
Feb 28, 2010 | Samsung Televison & Video
I have a sharp-aquos flat screen tv model#LC-37GB5U and my problem is it turns itself off and then wont come back on.yesterday it worked perfectly,today it wont even turn on.when i push the power button...
Power supply board it dead.Replaced the power supply board should solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board. .
Jan 20, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
TV does not power on. No Stand by light either.
Your power supply is shorted out. Get a good repairman to fix it..."exspensive" repair if you screw it up.
Apr 30, 2008 | Insignia IS-LCDTV32 32 in. Television
MITSUBISHI TV STOPPED WORKING
If you can do self test diagnosis, read threads here on Mits, or goto ctechnicians.com
Dec 16, 2007 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
