I get the following error when closing MS word: Word cannot save or create this file. Make sure your disk is not full, write protected or damaged (c:program files...Normal.dotm). Can anyone help, pls?
The Access Fix Toolbox utility is designed to recover damaged Microsoft Access databases. The Microsoft Office Access Fix Tool reads and analyzes damaged files (.mdb, .accdb) and saves recovered data directly into a new database. https://www.fixtoolbox.com/accessfix.html
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
Click Start and right-click Computer .
Select Properties .
Click System Protection from the left side of the Window.
In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window.
Figure 3: System Protection tab with D: drive unselected
Right-click Start Explore All Users .
Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
From the file menu, click Tools , and then select Folder Options .
Select the View tab.
Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
From the Folder Options window in explorer, double-click Recovery (D:) .
If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
Find and delete any files that you previously copied onto the Recovery (D:) drive.
CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
Press Shift + Delete to permanently remove the files.
To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
To set Windows Folder Options back to their original setting as follows:
From the explorer window press Alt to view the file menu.
Click Tools , and then select Folder Options .
Select do not show hidden files and folders and select Hide protected operating system files .
Click OK .
Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
If your company was using MS Office 2003 then you're using MS Office 2007. Make sure you're saving the file in a compatible format. For example, if you've create a report on excel file using MS Excel 2007 then you should save the file in .xls (compatible format) instead of .xlsx (2007 format. In that case you can open your file on both versions. Also when you're saving other office files make sure it's in compatible format.
I recommend you three password recovery tools, anyone of which can solve your problem with great ease. ❀This first one is Word Password Recovery 5.0. which is specially to remove ms Word passwords including password to open and password to edit. ❀The second one is Office Password Unlocker, which is office password recovery kits. Including password recovery tools for ms word and ms excel. ❀The third one is Password Unlocker Bundles. This program is an all-in-one password recovery kit. It contains rar password recoverytool, windows password recovery tool, office password recovery tool, ms word password recoverytool, ms excel password recoverytool, winzip password recovery tool and pdf password recoverytool ,ect
Make sure the disk is clean and you do no have any virus protection running while installed. Disable you virus protection.
Go into My Computer, right-click on the drive that contains the CD, Select Copy.
Navigate to your Desktop or other location you will remember. Right-click Paste. (This will create a folder of all the files on the CD Drive where ever you paste them)
If the disk copies successfully, open the folder you have just created. Run the Setup.exe application and install. (However, if it fails to copy there is a problem with the CD or the CDROM drive. In most cases a cheap drive replacement is always available.)
This problem usually occurs when the spin rate of the disc and drive are not transferring data sufficiently to install. This can also be interrupted by virus protection that is reading every file being installed. Other possible problems are loose drive cables, software, poorly burnt discs or damaged media.
