Question about Mitsubishi VS-6043 60" Rear Projection Television
Monoscope signal how to get it Mitsubishi VS-6043 rear tring to adjust the picture its all warped looking got tv out of ditch tring to make it work
  • 505 Answers
Does the convergence align or move? how is the picture distorted? if the picture aligns but is just warped, use a jig or some string to have some straight lines to reference for your geometry and convergence. the monoscope signal is hard to find and mits had it on a vhs tape back in the day. it really just helped you get the horizontal and vertical size and get a round circle to fix the warp.. just try to make all the grid points about the same distance apart and make it an even grid.
Posted on May 26, 2010
Testimonial: "thanks for helping"
I have sound but no picture
Use your mitsubishi remote and press the menu button which will open up the menu screen and you will see the picture in the upper right. Now you press 1370 then the enter button and you picture will be restored. This is the factory reset for all mitsubishi projection tv's
Dec 03, 2011 | Mitsubishi VS-6043 60" Rear Projection...
MyMitsubishi VS-6043 Big screen TV just started to black out while we were watching it.I would turn it off and back on the picture would be there. Now the power light goes on but the screen is black. Is...
Not sure on that one. My local repair guru tells me the 6043's are constantly having problems. I've got one that I'm looking for board parts for, so if you end up not wanting to fix yours, I'd love to get your board set for some parts.
Nov 11, 2009 | Mitsubishi VS-6043 60" Rear Projection...
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
11-year old Mitsubishi VS-6043 picture flickers and bends
check for cold solder joints on the yoke connector located behind the speaker grill and mounted on the crts. You may also want to check for cold solder on the vertical output i.c.
Jan 08, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
6043 6061 parts interchange
Well, you can use most of the parts, except that the shape of the boards are different, so you cant exchange the entire board as such.
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Will vs-6043 parts interchange with vs-6061
What specifically are you looking to interchange?
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
321 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
