Question about Lexmark X4690 Wireless InkJet Printer
Computer does not see the printer "communication error". I have used the Lexmark diagonistic tool, have reloaded the drivers. I have disabled the firewall. Still doesn't work. Was working some of the time but would usually have to reboot to get it to communicate with the printer. Now it doesn't communicate at all.
    Scholar:
  • 94 Answers
If your using USB cord try to change the USB cord of your printer because its maybe have the problem for it. But if it is also does not work just see the USB controllers at the Device Manager if their's no a problem from it. Just Right Click the My Computer, select Properties, go to Hardware, then click Device Manager and see the Universal Serial Bus Controller if they dont have any question mark (?) or apostrope (!). Because if they have any mark like that do you have a problem about your USB device. You just install the driver for that USB device to make sure that your printer will detect from the USB.
Posted on May 26, 2010
Printer say's "please load paper in auto
This could be a printer driver problem. Try to uninstall your existing Lexmark X4270 printer driver from your computer. On your computer, go to Start menu > Programs > Lexmark 4200 Series > Tools > Uninstall. After the process, reboot pc when prompted.
Check if your Windows 7 is running on 32-bit or 64-bit operating system. Go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the links below to re-install the printer driver on your computer: - Lexmark X4270 Driver for Microsoft Windows 7 for 32-bit - Lexmark X4270 Driver for Microsoft Windows 7 x64-bit
Jul 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
Cannot find disk to install my printer
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
May 04, 2011 | Lexmark Computers & Internet
Printer does not Communicate (connect) following Microsoft SP3
I figured out the solution. Download the printer driver here http://downloads.lexmark.com/static/229-1-0-486.html#
Jan 28, 2009 | Lexmark Z600 InkJet Printer
Lexmark 730 Communication Not Available Error message with Vista
The first thing make sure your antivirus software has exception for Firewall Program Exceptions for allow access ..for the follwoing programs like "Printer Communication system" or "Lexbec server" or "Print Spooler" etc..If you dont know to check exceptions or create on try disabling the firewall and check..if your antivirus is expired uninstall it completely first..
then try this
Reinstall the Printer driver in the following Method..
Disconnect the Printer
1.Click>Start>Control Panel>Printers and Faxes and delete the The Printer that you are reinstalling the driver for delete all if there are more than 1 printer of the same.
2.Go to Control Panel>Add/Remove Programs> Uninstall the Lexmark related Programs
3.Restart the computer
4.Start > Run > Type in "cmd"
5.now you will have command prompt Type this and hit enter "net stop spooler"
6.Click>Start>Run Type in "C:\WINDOWS\system32\spool\drivers" Hit Enter
7.You will have the following folder open rename the W32X86 folder to W32X86.OLD
8.Restart the computer
9.Insert the Lexmark CD and start installing the software Note : Connect the Printer only when the installation is prompted to connect..
This should defnitely take care of your problem..
Note if you are using vista try this first
Start type msconfig open that go to tools tab and disable UAC and restart and check..
Jan 28, 2009 | Lexmark Z735 InkJet Printer
Loading Software
install the printer driver first (do not connect the printer yet until installation procedure asks you to connect the printer)
then set it as your primary printer
Nov 04, 2008 | Dell Inkjet 720 Printer
Error 1200. i have tried to resolve using the steps in the manual. No luck The model is Lexmark 4720 Maltifunction printer
I managed to fix the problem. Error 1200
Checked for paper jam, no luck
Unplugged the USB connection and from the wall socket, no luck
Took the cartridge out and reloaded them again, no luck
Switched the whole computer off and then logged in back again, no luck.
Uninstalled the software.
Installed the software, driver, message "computer cannot communicate to the printer", but the scanner, fax and copy started working.
Deleted all pending jobs
Shut down the computer then logged in again.
Bingo, the printer started working.
Hope this helps
regards,
Tara
Sep 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
My PC (Windows XP) recognises my Lexmark X2550 all-in-one printer, but won't print to it. The drivers have been loaded and reloaded to no effect. I keep getting a communication error in a dialogue box. I...
Go to Start, Printers and Faxes. Right click on your printers and select properties. Click the port tab. If you are using a parallel cable make sure LPT1 is checked. If you are using a USB cable makes sure USB is checked.
Jun 02, 2008 | Lexmark Office Equipment & Supplies
It just won't print!
try to make un-install drivers for the printer, then reboot and install driver agin.
I think, it might be your driver currepted and cause this problem.
Please post your feed-back.
Gud-luck
Iqbal
Apr 15, 2008 | Lexmark X3480 All-In-One Printer
Lexmark X4690 Wireless InkJet Printer Logo
101 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
