Question about AudioBahn A1300HCT Car Audio Amplifier
No power My amp is running 2 12" audiobahn 700's. I just bought this amp brand new not even a month ago. It was running fine and then i lost sound and looked back and the blue light in the center of the voltage meter went red, then i lost all power to the system. I checked the in-line fuse and noticed that it had blew so i put in a new and as soon as i turned it on, that fuse blew. Why is this happening and what can i do to fix it?
  • 62 Answers
May be the coil filter choke is wornout...DC supply stage inside your amplifier...go to the nearest electronic tech to repair that..
Posted on May 26, 2010
I lost the combination so haven't locked it for fear of not getting it open again
that doesnt sound safe!have you tried emailing the manufacturer with a serial number and model number.to ask for combination.
Apr 17, 2016 | Locks & Locksmithing
Hi, on my JB5538 Wristech, even with brand new batteries, the unit never seems to inflate ! It developed this problem about 3 months ago out of the blue. Keep getting Err message. How do I fix it ? Th
either the compressor unit seals are damaged or you have a hole in the inflatable section either way it is not an easy fix and as they have come down in price dramatically over the past year i would suggest buying a new model & chucking this one away
Nov 12, 2014 | Health & Beauty
I just put a brand new battey in my 95 katana but it still.loses power and dies and wont start
Sounds like your regulator/rectifier has failed. This is a fairly common fault on GS and GSX models, particularly the smaller capacity (below 750cc) models. Did the oil level fall below minimum at any time, because this can cause the generator on some models to overheat, causing a power surge which can burn out the regulator. Get the generator checked and fit a new regulator/rectifier.
Oct 10, 2012 | Suzuki GSX 600 F (Katana Motorcycles
Bought new few years ago. i get adead string only on the b string & only first 3 frets-clears up at 4 fret-g string fine -e string fine. sometimes clears up by itself & is fine 4 few months.If prob...
Sounds like your truss rod needs to be adjusted. This should only be done by a professional. Take your guitar to a shop or guitar store that offers a service like this.
If you really want to do this yourself, though, here's a helpful video that will take you step by step through this:
Hope that helps!
Jan 30, 2011 | Epiphone Les Paul Special II Guitar...
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
Heeey. I have the Audiobahn A2300HCT and it has a very strange problem. When i start the amp its in the normal blue mode but i have no sound. The one power output (LEFT) indicator shows +3DB (full) the...
My brother just bought an A2300HCX and almost the same thing happen. 1 of the gauges (left side) was no movement. We tryed hooking the amp to the right side, and it works. The Left side turns out was shot, had to get it fixed. So sorry to tell you but sounds like one of the channels has internal damage. I know this isn't the good new you were wanting to hear, but hope it was helpful
Apr 08, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Amp blows main power fuse..
No "fault" lights? If not it HAS to be a connection...whether they look bad or not, Redo them, ground FIRST.
Good Luck
Jun 21, 2009 | AudioBahn A8002T Car Audio Amplifier
Compaq presario 700 Black screen
There might be several reasons, hardware nor software/operating system, but most probably from the hardware. Can be the graphic card (if you can notice the hard disk work well - from the sound), can be the hard disk, or even the mother board. We have to go through the symptom.
Since it is still new, the best solution is back to the seller for guarantee.
Feb 27, 2008 | Compaq Presario 700 470024-192 Notebook
Audiobahn A2502DP amp is alive but wont talk to me
Your "bumpin" may have killed the amps "bumpin" Was the amp secure when you were sliding? So wires are ok, and lights and finas running. You have power but no output..Check the settings on the amp, also the fuse. Something might be earthing itself to the amp as well.
Feb 14, 2008 | AudioBahn A2502DP Car Audio Amplifier
AudioBahn A1300HCT Car Audio Amplifier Logo
108 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
