Question about Vizio JV50P 50 in. Plasma TV
JV50P has power but that's about all
Opened it, found three fuses, all check OK. Power up clicks a relay or two, and three green lights flash for less than a second on the board (about center of the chassis) stamped A1 and holding a large (about 1.5 in. square) IC identified as IC101. Those are the only visible signs, no screen light up, no audio.
  • 1 more comment
  • thielectronick
    thielectronick May 26, 2010
    something is causing shutdown. can you turn it back on or do you have to unplug to get it back on? something may be shorting it out but still not blowing the fuse. check with an ohm meter the Vs and Va voltage lines to cold ground. if any show a short, unload plugs to find your issue. this has a switch mode power supply, so dont fully unload the power board and switch it on, it will damage the supply. it needs a load.
  • glroach May 26, 2010
    The behavior described is repeatable by power on/off at the power switch. Unplugging changes nothing.
    Not sure what you mean by cold ground, but here's what I did.
    With AC unplugged, I located connector on power supply board marked with Vs and Va. Unplugged the "daughter board" connector(the board receiving from the power supply board) and did ohm check at the daughter board. Used chassis as the "ground" for ohm test.
    Two Va pins show resistance in the 2Kohm range. Three Vs pins all show resistance less than one (1) ohm.
    Left that connector unplugged and powered on; no change in behavior.
  • glroach May 27, 2010
    It appears that the Vs pins on the board 50X4A_Z are shorted. Unless I'm missing something, this board is directly connected to the screen by two copper-colored ribbons and soldered connectors. Got a feeling this is way beyond my skills. Thanks for your guidance. Will hit the rating as soon as finished here.
  • 505 Answers
If Vs is showing less than 1 ohm, that is your shorted line. it goes the sustain and address boards (big boards on left and right side of set) and one of those is bad. try using the same ohm check to see which is shorted and replace that board to fix the set. if it is the address board (one that plugs into boards with lots of chips addressing each horizontal line of screen) you need to check all the address buffer chips. make sure there is no little pin sized hole burned into one of these chips or it will blow out your new address board.
other names for boards
address = Y sustain
sustain = Z or X sustain
Posted on May 26, 2010
Testimonial: "Guidance was clear and within the skills of an old engineer with minimal tools. Sadly, correcting the problem requires more tools than I have, so the set will have to go to the shop after all. Thanks for being online."
  • thielectronick
    thielectronick May 29, 2010
    Sounds like you've narrowed it down to that Z board. If you can find one, it should be an easy board swap. The ribbon connectors are a bit tricky but just be very careful with them and make sure not to rip them (they are part of the panel and not replaceable). Just unscrew the board and swap, plug in all cables and away you go. There may be a part number on the board or you may be able to contact Vizio for a part. The tricky ribbon cables are sometimes easier to re-attach if you slighly lift the board as you insert them (attach before screwing in board) - easiest with tv laying face down on a soft blanket. Let me know if you have any other questions.
My Teac AG-V3020 makes clicking relay sound when attempting to power up.
recheck your connections it appears that something is cross if so recorrect the connections on your system
Nov 29, 2014 | Teac Audio Players & Recorders
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
No want to start,no light check engine on,
Maybe I can give a little help. Do you have the 4.0 liter straight six engine? This should apply as well if you have the V8 engine.
:...no check engine light...:With key on, does the light turn on? If not, it may not be getting power. Have to check that first, check all fuses in the under hood relay/fuse block. The check engine light should turn on with key in on position, just as an alert that the PCM is powered, and ready to work.
"...no electric to coil..." With key on, the dark green/black wire to the coil should have battery voltage. In that fuse/relay block will be a relay called an Automatic Shut Down relay (ASD relay). When the PCM turns this relay on, power is sent to the ignition coil on the green/black wire. The power feed for the ASD relay is fuse 2, a 20 amp fuse in the Power Distribution Center -the fuse/relay block under the hood.
So you have a couple of things to check: Make sure the PCM is powered. If it is, hold your finger lightly on the ASD relay while someone turns the key to on. You should feel it click on. If it does, but no power at the coil, check if fuse 2 is sending power to the relay, and check the green/black wire from relay to coil. If no relay action, possibly a bad relay, or the PCM is not turning the relay on.
Good luck. Let me know what you find.
Jan 04, 2014 | 1995 Jeep Grand Cherokee
99 town and country quit now even the warning lights dont come on
from ignition switch
key to run
black/orange power to fuse 11 and 12 in junction block and fuse 1 in power ditribution center
power to
black/white
dark blue
dark green/red
power all times
pink/black
red
pink
gray/black
check the maxi fuses
Mar 13, 2010 | 1999 Chrysler Town & Country
1998 f150 4x4 not working
Check BJB ( aka Battery Junction Box, Engine Compartment fuse panel ) Fuse #17. This is the power to the Transfer Case shift relay, which powers the Shift motor in the Transfer case and power to the magnetic clutch coil ( via the transfer case relay ).
The other fuse to check is the CJB ( aka Central Junction Box, cab fuse panel ) Fuse #23.
If both fuses check good, time to check for power on the connector for the shift relay and the shift motor. The power from BJB Fuse # 17 is the Dark Green w/ Light Green stripe ( this is hot at all times ).
The old school test is to lightly hit the back of the transfer case, to see if the shift motor is hung up.
Here are the diagrams, so you can see what I am talking about.
Dec 18, 2009 | 1998 Ford F150 Regular Cab
Planar PDP-42BK PDP42BK blowing PSU fuse repeatedly - 2 bad 5W Rs
You must replace the drivers, the output/chopper transistors and use the correct type of R2/3 resistors otherwise you have a fire waiting to start.
Feb 26, 2017 | Planar PDP-42BK 42 in. Plasma HDTV
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Won't power on...
Unplug the TV for a minute then plug it in while observing the power light. If the light flashes three times then the standby power supply is OK.
If the standby power supply is OK, a diagnostic code can be read from the green power light by counting the flashes. Press the power button once (this sets the diagnostic code). Press and hold the INPUT and MENU buttons on the fron panel for 5 seconds then release. The green light flash a two digit code (x flashes, followed by a pause, then y flashes). If it flashes a 2-2 code then a short circuit has been detected in the switched power supply. It would normally flash a 1-2 code for "no problem detected".
If a 2-2 code is read, check for blown pico fuses on the POWER circuit board. If the FA904 or FA905 fuses are blown then most likely at least one of the two convergence driver ICs are bad. It seems like this is the most common failure. I replaced these fuses and ICs in my TV. The parts cost me $50, but it required extensive disassembly, PC board desoldering & resoldering, and reassembly. If you can resolder circuits on a PC board then you can probably fix it yourself, otherwise call a repair person.
Sep 07, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Aug 10, 2008 | Dishwashers
Panasonic PT40LC12 - Blinking green power light - no lamp fire up.
Had similar issue but had high resistance across leads. replaced with thermal fuse from RadioShack in the similar temp and everything works great. Info on the original part is on this link. http://www.willas-array.com/prod/products/directory/pdf/sefuse/FUSE_SMG.PDF Hope that helps. Chris
Apr 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Vizio JV50P 50 in. Plasma TV Logo
361 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
