Question about Compaq fs740 17" CRT Monitor
MONITOR SCREEN KEEPS BLANKING OUT WITH A ORANGE COLOR OR BLUE COLOR
I have a compaq fs740. While I'm working on the computer the entire screen will turn entirely orange or blue with slightly slanted lines. I can slightly see my information stil in the background. I have to wait for the screen to turn back to normal which may take a few minutes or a few hours.
It is one coulour missing and it can b mostly due to CRT socket loose or some dry solder in CRT {RGB) path..
Chck out...
This is a technical freak from INDIA!
Posted on Apr 07, 2008
SOURCE:
Compaq monitor FS740 is turned off after some time
Step 1:
Check your screen saver setting.
Step 2:
check your monitor setting to always in active mode.
Jan 10, 2013 | Compaq FS740 Color Monitor
Monitor changes color like green, blue etc. How to correct/repair this.
plug and unplug vga cable or try contect it with diffrent vga cable.
Sep 04, 2011 | Compaq fs740 17" CRT Monitor
Inherited Compaq FS740 but after hooking up monitor will show green for a short time and then color is yellow? Is it dead? Has set up for a while
Check the pins on the cables. Single color presentation but clear picture indicates the pin for a particular color is borken on teh cable. Remember Red Green and Blue are mixed to make other colors. If you have predominantly one color then its due to cable not haveing all pins inserted properly or damaged.
Jun 28, 2010 | Compaq fs740 17" CRT Monitor
Monitor keeps going blank, then once this a.m. it cycled in colors, white, red, green, blue, grey- very weird... what's up with that?
it's doing testing in color codes to refresh the color on the screen, if it keeps going blank, that's usually a sign of monitor going bad.
Oct 16, 2009 | Westinghouse L1928NV Monitor
Monitor screen problem
Check your cables. Make sure they are secure.
Apr 07, 2008 | Compaq fs740 17" CRT Monitor
Monitor is tilted forward and wont tip back
it will tilt back, just make sure the stand is in the forward most position and not turned and hold the screen at top and push while at the same time pull at the bottom, it will be quite stiff.
Sep 23, 2007 | Compaq fs740 17" CRT Monitor
Compaq monitor
OK your monitor is failing in the Horizontal circuitry.... OR the PSU is failing to supply the correct Voltages. Either way it is probably going to fail completely soon. With monitors so cheap now, here in NZ they are about NZ$20.00 - $50.00, repair isn't adviseable to do so, it would make more sense to put the Repair monies into a NEW screen... maybe time for an LCD?
Jul 22, 2007 | Compaq fs740 17" CRT Monitor
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Concave screen problem also
OK All these Compaq's have a Power Supply problem, or a Horizontal Voltage problem.. meaning they are on the way out. The SMPSU's in these units often fail along with the Horizontal Drive Circuitry. I think it is time for a new one? Repair of such a unint would barely be "Ecconomical" IMHO.
Jun 08, 2006 | Compaq fs740 17" CRT Monitor
Open Questions:
See all Compaq fs740 17" CRT Monitor Questions
Compaq fs740 17" CRT Monitor Logo
341 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
