Question about Mitsubishi WD-62526 Projection TV
My mitsubishi wd-62526 red light is on for lamp and there is no picture
  • 505 Answers
This indicates a bad lamp. your owners manual has instructions for replacing. there will be a lamp door on the back or behind the speaker grille. if the lamp is shattered or bulged/white it is bad. if the lamp looks good, you may have bad capacitors on your power supply.
Posted on May 26, 2010
5 Suggested Answers
  • 108 Answers
SOURCE: Mitsubishi WD-62526,no picture,no sound,status LED
According to the manual this means the Lamp cover door is open or lamp cartridge is not secure.
See Appendix F for lamp replacement information.
Posted on Apr 04, 2008
SOURCE: Need to replace ballast on mitsubishi wd-62526
I replaced my own the part cost $109,it was somewhat time consuming since taking the back panel off was a learn as I went.However I still didn't get the red LED to go off.....TV still would not power up in it's normal fashion.Previously I had 2 lamps burn out,and you definetly could tell they burned out.Since then I have changed the power supply feeding($130) the ballast circuit and I still haven't got the TV to come on without defaulting to the red LED,and taking the chasis apart to do this was a real pain.I have posted a question about my problem recently.Still waiting for a solution.Mitsubishi won't sell a customer any parts........they want you to go to atechnician that works on their product.GOOD LUCK!
Posted on Jan 07, 2009
localwonder
  • 6784 Answers
SOURCE: wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Posted on Sep 02, 2009
SAMUEL011
  • 39 Answers
SOURCE: My mitsubishi wd-62526 will turn on with sound but
Hi
Having in mind that a generic lamp will give you 4500 to 6500 lamp hours and the Phillips will give you 6000 to 8000 lamp hours and that you TV is 4 years old more likely you are looking to replace you lamp;The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp.
You can check DM;
If you can hear your TV fan working is NOT you power supply,but if you hear a constant clicking you ballast needs to be replace,
A ballast is an electrical component used with a fluorescent bulb (or mercury vapor lamp or arc lamp) to conduct electricity at each end of the tube. It supplies the initial electricity to the bulb that creates light, and then it regulates the amount of electricity flowing through the bulb so that it emits the right amount of light.
You can find your parts at:http://www.discount-merchant.com/SearchResults.asp?Search=HD50LPW175?Click=52978
I hope this will help,please keep us posted.
Posted on Oct 01, 2009
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
Mitsubishi wd-62526 error code 45
It's a lamp fan failure part no. 299P296010, its available at ebay and tvserviceparts.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
Whats the best replaceable lamp for my wd-62526 tv?
It would be a philips lamp!!! They're the best in the market, discountdashmerchantdotcom :) take a look around and you'll see :P
Jul 03, 2009 | Mitsubishi WD-62526 Projection TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi WD-62526
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62526 Projection TV Logo
615 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
