My Sharp Notebook PC GP10-CM screen has suddenly stooped working. What can I do to fix this?
    Problem Solver:
  • 23 Answers
Can u hear the sound of the processor, if u can i'm afraid you will have to take it to the nearest repair shop.
Posted on Apr 07, 2008
  • Obakeng Diale Apr 07, 2008
    thanx for rating me
MY tv is not getting turned on Manually/ Remotely..!
First if now total dead it has a fuse inside to look at.
Jun 14, 2012 | Venturer 19 inch flat screen TV
I cant fix the backlight of the lcd screen of my laptop
If the Video Cable is damaged, you may want to think about obtaining a new one.
Apparently your solder connections didn't work, or you haven't repaired all of the damage.
Wires could be stretched and broken inside their insulation sheath, and you may not see it.
Use a multimeter, and perform a continuity test of each wire.
Inside the sheath of the Video Cable are wires that lead from the motherboard, and go to the screen Inverter.
You know this.
What you may not know is there are wires inside the sheath of the Video Cable, that lead to the wire/s going to the screen Inverter.
One of these wires may be damaged down in the sheath, and is not visibly apparent.
Suggest replace the Video Cable, and put your mind at ease that it is not the problem.
The CCFL in your Display Assembly is about 2mm Thick, and almost as long as the LCD screen is in height.
Not knowing the exact manufacturer and model number of the laptop;
1) I can't tell you if their is just one CCFL, or two.
The CCFL bulb should be located on one side of the LCD screen assembly. (Unless it is a dual CCFL model)
2) I can't tell you if your LCD screen backlighting is CCFL, or a series of LED lights.
It has been posted that you laptop may be a Sharp PC-GP10-CM
[ http://www.ebay.co.uk/sch/i.html?_nkw=sharp+pc+gp10+cm ]
The wires leading to the CCFL bulb are soldered to the ends of the bulb. Perhaps there is a bad solder joint,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Me?
I would replace the Video Cable.
Regards,
joecoolvette
Apr 25, 2012 | Computers & Internet
I have a sharp PC-GP10 CM laptop but the screen has gone black after my daughter pressed a button. I dont know what she did. I have rebooted and the laptop comes on but the screen is still black. Any...
Look for the Fn Button bottom left of the keyboard. Hold this button down then press F5. You should see the screen flash up. Have an external monitor connected to the vga output on the back of the sharp while you try this. The Fn Key and F5 combination is used to swith modes between laptop and external monitor, Dual view etc. You should see some activity when you do this. Hope this helps you out. Ps... Using the Fn key with F6 and F7 will Alter the brightness of the screen on your laptop.
Oct 14, 2010 | Sharp Mebius PC-PJ2-S3 Notebook
I HAVE A SHARP PC-GP10-CM MODEL THAT I WANT TO CONNET TO THE INTERNET WIRELESS, HOW DO I GO ABOUT IT PLEASE HELP.
First you need to sign up with an Internet Service Provider than can provide a broadband connection wirh DSL (ADSL in Australia) or a cable connection together with a wireless router with a built-in DSL or cable modem. Alternately a wireless router plus a separate DSL or cable modem.
The modem needs to be configured in accordance with the ISP's instructions.
Then the Wireless router and the wireless card in the computer needs to be configured. Follow these steps:-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
If you are not sure, then get a computer savy friend to help you.
Oct 21, 2009 | Sharp Computers & Internet
Intermitant blank screen on sharp PC-Um10
The thing to do is analyze IF the problem is the machine is going to sleep OR just the monitor portion.
AS A TEST connect an external monitor and see if it winks out as well.
IF IT doesn't then either the backlight power supply is failing OR the monitor power saving setting is corrupt.
ALSO verify that the power cord is not intermittently disconnecting (common problem) as this can cause the screen to be shut down on some setups.
Sep 11, 2009 | Sharp PC UM10 (PC-UM10M) PC Notebook
Mebius pc-gp10-bm vga driver
1.Definitely you can get your drivers .
just go to ur motherboard manufacturing site or google , click on download section click on drivers, enter mother board number and download the drivers free.
2. If you don't know the motherboard drivers name and exact number then connect to internet, uninstall all the old video and audio drivers or restart the system. then when pop up window says that new hard driver is found then click it and it will automatically install drivers from net
3. If you want to know about your motherboard drivers, then go to desktop
a. right click on my_computer,
b.then select properties, in properties tab click on the HARDWARE tab,
c.then click on the device manager tab, then select and expand the drivers like sound or video which you want to know.
d. right click on the selected sound or display drivers and select its properties.
e. select driver tab and the driver name and version will be before you. and again repeat the step 1 again
Thanks & Regard
Pravin jha
Great India
Jun 15, 2009 | Sharp Mebius PC-PJ2-S3 Notebook
AVEO USB2.0 pc camera not working
www.download.com
you can download generic driver from here it is safe legal and free
as it seem as driver problem
May 09, 2009 | Computers & Internet
YOU NEED DRIVERS, CORUPT DRIVERS, UPDATE DRIVERS, MAYBE NEW SOFTWARE, CONFLICKING SOFTWARE OR NEWHAEDWARE INSTALLS OR UPGRADEING YOUR INTERNET PROVIDER LIKE FIREFOX3.X
HERE ARE SOME SITES TO LOOK UP YOUR INFORMATION;
WWW.NEC.COM
WWW.WINDRIVERS.COM
WWW.USB.ORG
WWW.USB.COM
WWW.PC-CARD.COM
WWW.IRDA.ORG
WWW.IRDA.COM
WWW.DRIVERSHQ.COM
ROD
Feb 09, 2009 | NEC Versa VX Notebook
I have problem with my screen
hello ...i have the same problem and situation.Unfortunately that damaged the LCD already bec the glass cleaner absorbs the liquid that makes it unresponsive to taps. You got to have that replaced or have that checked by authorized dealers or repair centers.
Apr 11, 2008 | O2 Xda IIs Pocket PC
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
