Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool will not run it is control lock - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • 1,382 Answers
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Posted on May 26, 2010
I have a whirlpool gold dishwasher. The controls locked light is on and I can not get it to shut off. I can not run the dishwasher
In reading the manual, it shows the following:
To turn on Lock, press and hold Control Lock for at least
3seconds.
To turn off Lock, press and hold Control Lock for at least
3seconds.
Jun 07, 2015 | Whirlpool Dishwashers
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Gold quiet washplus dishwasher Red Light staying on--control locked Cannot get it to run, no buttons will do anything
Which model dishwasher do you have? The Control Lock is a feature that keeps a child from starting the dishwasher when it shouldn't run. The Cancel button will work but not the Start button.
On the DU920QWD, to toggle the Control Lock off, press and hold Air Dry for 5 or more seconds. (Holding it again will turn on the lock.) Most dishwashers will have a the Control Lock key labeled with text in a small font for how to enable the Lock. The direct link to the DU920QWDB4 manual is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203376817.pdf .
For other Whirlpool dishwashers, the Control Lock sequence will be listed in the manual. You can get a PDF of many Whirlpool appliance manuals from http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . Enter the model number (from the rim inside the unit) and click on the right arrow.
I hope this helps.
Sep 08, 2011 | Whirlpool Dishwashers
Model #GHW9100LW2. Control lock light is on and i do not have a manual. How do I turn off the control lock so I can run the machine?
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however, your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Whirlpool Washing Machines
Whirlpool duet dryer is stuck on control lock mode. Have tried pressing the end of cycle button for several seconds and control lock button stays on....dryer won't run.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#!#!
Jun 27, 2010 | Whirlpool GEW9250 Electric Dryer
How do you get control lock off whirlpool duet washing machine
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Jun 30, 2009 | Whirlpool GEW9250 Electric Dryer
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
May 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Dryer GGW9200LW1
this is your child lock
look in your manual how to unlock
Jul 31, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
124 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
