Question about Desa International White Wireless Plug In Door Chime
The sending unit is broken. The chime is OK. The chime number is TR-6505 RX above the Made in China, and 390-6505-RX along side the DESA SPECIALTIES PRODUCTS, Nowling Green, KY. Can I get a new sender for this chime?
4 Suggested Answers
SOURCE: I have a wireless doorbell made by DESA
You can buy a new wireless doorbell intercom camera units.
Posted on Dec 31, 2010
SOURCE: I have a desa TR-0081-BX
There is a little "diode" that should have been provided as part of the unit...it's a little wire with a B-B-sized circuit in the middle that has to be connected to the push-button at the door. This "extends" the circuit from the button to the chime unit for the full 8-notes. Hopefully you still have that part (I just about threw out mine before I read the instruction manual thoroughly. My diode just "shorted" after I power-washed my house...and I am in search of that particular part. I contacted Heath Zenith...hopefully they will give me a solution on how to get only that part. In any case, you need that diode to get the chime to play correctly.
Posted on Mar 27, 2011
  • 3 Answers
SOURCE: I bought a new door
ok.the bell have number or setting put the number in the right order.one at a time.good l
Posted on Apr 01, 2011
I need a new push button for an sl6195 rx
Heath-Zenith (I beleive they bought DESA) makes a battery remote push button bell that says its compatible with all Heath Zenith chimes. I bought one at Home Depot and it worked for my SL-6195-RX. (an on line doorbell seller and the Home Depot assoc all said it wouldn't work.)
UPC is 16963961975.
Item also shows a code "11G43" on a sticker on the back of the package.
Nov 04, 2011 | Desa International White Wireless Plug In...
I have a desa TR-0081-BX wired door bell. When you push the button it only gives a short chime . If you hold the button down it goes thru a 8 note chime what can be done to fix this. There is only one...
Mar 15, 2011 | Desa International White Wireless Plug In...
I have a door chime SL-6195-RX with outside door push button. I have changed batteries in both units and still does not work.
The contacts in the outside push button unit may need cleaning. They do get dirty over time. If that doesn't solve your problem you can contact the Zenith Company, who is now is the manufacturer for tech service issues. 800-858-8501.
Hope this helps solve your problem.
Mar 07, 2011 | Desa International White Wireless Plug In...
Why does chimes sound when no one as pressed bell
water can get into the button on door inside is a spring that pushes a part of the switch away from the other and when someone presses it they join together and bell sounds but if the rain gets inside it can make an electrical connection between the two points open it up and see if there is any trace of water the just put a bit of pva glue over the top join on the switch it will water proof it and will also be easy to remove or it could be a low battery or if mains anything can set them off mobile phones tv any thing that sends a rf signal its best to have as small a gap as possible between the two units
May 20, 2010 | Desa International White Wireless Plug In...
I have a wireless SL-6151-RX-A door chime and it does not ring
Check that the dipswitches on the button and the reciever doorbell unit match. Also verify that your battery is not installed the wrong way.
Nov 15, 2009 | Desa International White Wireless Plug In...
SL-6195-RX seems three houses have the same
Open up both the button and the main unit and switch the codes with the pins. It done on a row of pin sets - Default is usually connectors on 5-6-7 (8 is on the main bell unit and causes the ding-**** to change to a Westminster chime).
With a pair of needle nose pliers pull the connector and set them on different numbers. You must do this on both pieces, When you have a unique code its no longer an issue with the neighbors.
Aug 02, 2009 | Desa International White Wireless Plug In...
Desa International White Wireless Plug In Door Chime Logo
73 people viewed this question
Top Desa International Home Security Experts
Steven R
Julian Pearson
Level 1 Expert
Halim Hartono
Halim Hartono
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
