Question about Canon PIXMA MP780 All-In-One InkJet Printer
Jammed After I changed a printer cartridge the machine will not work at all -- the part that moves back and forth to scan or copy the image (I cannot think of the name at the moment -- pardon my imprecision) appears to be stuck. When I changed the printer cartridge I had a hard time getting everything back into place, including the part that holds the printer cartridges and the top cover; although I don't think I forced it shut I must have damaged something.  Is the machine a goner?
    Novelist:
    Champion:
  • 214 Answers
As you should NOT have had the problems you have described when changing the Ink cartridges, I am led to believe that something may have been forced out of place.
Try reinstalling the Ink cartridges (scrupulously following the instructions) and see if everything clicks gently into place, then try the machine again.
If this does not work, take it to a repairer and get them to check it out (remember your warranty if it is still valid - though this may not apply in the case of physical damage caused by the operator). It may be something simple, so keep your fingers crossed.
Good luck.
Posted on Apr 07, 2008
6ya staff
SOURCE:
HP Photosmart Premium C309 with all lights flashing. Won't do anything, even scan. No resets work. All I want to do is scan. Help.
Either the carriage is jammed or there is a major electronic board failure. With the power disconnected, try to move the carriage back and forth with your hand. If it seems sticky, clean off the carriage rod and put a drop of light oil on it. Then work the carriage back and forth until it moves freely. Plug in and all should be well.
If this does not help and you can't find any jammed paper or objects, you have a major failure and it will be cheapest to buy a new unit.
Sep 22, 2016 | HP Photosmart Premium C309A All-In-One...
How to fix failed to initialize selected scanner?
Lift the lid as if you are going to make a copy of a document.. then whith the lid up turn the printer off still with the lid up turn the printer on and watch the scan lamp .. the light that moves when you make a copy. Verify that it lights up and moves back and forth. If it does not move back and forth the scanner lock may be in the locked position.. let me know..
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 03, 2014 | Toshiba E-studio 233 Multifunction Copier...
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Cartridge jam: tried all the suggested solutions; but still jammed. What to do?
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
Feb 08, 2011 | HP Photosmart C5580 All-In-One InkJet...
Printed images are grainy? especially the skins. any solution
This could be caused by a couple of things. The first one is the toner cartridge. A defective or low toner cartridge can cause light "grainy" looking copies. If you have a spare toner cartridge try that first. The second possibility is dirty scanner optics. The scanner bar that lights up under the glass and moves back and forth has 3 mirrors on it. When they get dirty is causes your scanned image (before it gets copied) to appear light and patchy looking. The glass must be removed by removing the 4 screws on the left hand side. Then the scanner can be pulled out and the 3 mirrors cleaned. If you have the machine hooked up to a computer to be able to print then these mirrors will NOT affect PC prints. If PC prints are grainy then that would point to the toner. The dirty mirrors will only effect the copies.
Good Luck and Thank You for using Fixya.
We are having a contest this month that is based on positive testimonials. If my solution is helpful please leave a short testimonial for me.
Thanks!
Oct 06, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Alignment problem- says to remove tape from cartridges, not sure what tape or what cartridges.
Did you recently install new ink cartridges?
See below, or go here and enter your model # , choose tech support and search "change print cartridge" for detailed instructions with pictures.
Overview
This article provides general instructions on how to change the cartridges on Lexmark Inkjet and All-In-One printers.
Procedure
1 Ensure the All-In-One printer is powered on. No image.
2 Lift the scanner unit or access door (per right-hand image).
The cartridge holder will move to the center of the Inkjet or All-In-One.
3 Press down on the cartridge carrier latch to raise the carrier lid.
4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image.
5 Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
6a Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge.
6b The image at right illustrates inserting the black cartridge.
7 Close the carrier lids so that they remain closed. See image above in Step 3. No image.
8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image.
9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
How to Change the Cartridges on Lexmark Inkjet and All-In-One Printers ID: ENUS32244 Overview
Procedure
NOTE: These instructions are general, and your specific Inkjet or All-In-One may appear different than the pictures below; however, the steps are the same.
Step Action Image 1 Ensure the All-In-One printer is powered on. No image. 2 Lift the scanner unit or access door (per right-hand image).
pattlnk_3232007_1123-01%20open%20scanner%20unit.jpg 3 Press down on the cartridge carrier latch to raise the carrier lid. pattlnk_1202009_209-hw_cartridge_carrier_lids_p.gif 4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image. 5 Remove the protective tape from the back and bottom of the new cartridge(s).
pattlnk_1202009_2013-remove_tape.gif 6a Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge. pattlnk_1202009_2024-color_install.gif 6b The image at right illustrates inserting the black cartridge. pattlnk_1202009_2016-black_install.gif 7 Close the carrier lids so that they remain closed. See image above in Step 3. No image. 8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image. 9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image. Still Need Help? If you require additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need the machine/model type and serial number (SN) of your printer.
Please call from near the computer and printer in case the technician asks you to perform a task on one or both of these devices.
Jul 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
MFC-9440 CN--Lines in my auto feed scanned/faxed copies
clean the thin strip of glass located under the document feeder with something non abrasive
Feb 06, 2009 | Brother MFC-9440CN Laser Printer
Printer not printing at all
Though there was no message to indicate toner issues, I changed the cartridge anyway. That must have been the problem. It works now. The old cartridge was 3 years old and, though barely used, may have outlived its quality. Thanks for writing back.
Aug 11, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Cartridge jammed and sccaning error
When you open the clamshell does the ink carriage slide back and forth with jamming?
If not then try getting some silicone grease and apply a very very thin line of it on the rail.
If it does then try making a copy, in the middle of the process, before the error, open it up and see if the ink carriage has even moved from "Home" position.
You might have a belt issue and this could be one of many things, stripped plastic gear, streatched belt...
Jun 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
What is the cartridge cradle
The cartridge cradle is where the ink cartridges are installed. It slided back and forth on a silver rail. If the rail gets dirty, the cradle can stick and not move freely. Try cleaning the rail with a soft clean dry cloth.
I've also see the cradle become disconnected from the belt that moves it back and forth. If that has occurred, and it is out of warranty, it will need replacement.
Jun 01, 2008 | HP PhotoSmart 7660 InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
26 people viewed this question
Clive
Clive
old marine
old marine
Ekse
