Question about Epson Stylus CX6600 All-In-One InkJet Printer
Get error message "Printer error: see your documentation and call service if necessary."
    Problem Solver:
  • 6 Answers
I found this on another website and it worked for me. It apparently resets the printer. Hope it works for you:
1.) power on (error message)
2.) press the "Stop (triangle)" and the "Colour copy" button and hold them
3.) press the power button to power off, still hold 2.)
4.) press the power button to power on, still holding 2.)
5.) the LEDs start to flash, then they stop to flash and the red exclamation mark starts to flash. Now release 2.)
6.) the LED should say: "Init EEprom"
7.) now press and hold the power button until the printer powers off and powers on again.
Posted on Jun 05, 2010
Van_Fanel
  • 25 Answers
SOURCE: printer displays erro message:
1.) Turn off the power and disconnect all cable connections ( usb cable and power cable ).
2.) Check for any obstructions in side the printer.
3.) While the printer is off and cables are unplugged., press and hold the on button for 10 sec., release after 10 sec., connect the power cable., turn on the power., check if error persist.
Posted on Apr 06, 2009
jacklee366
  • 541 Answers
SOURCE: It reads Printer Error - see your documentation
this means your printer waste pads are full and the printer needs to be reset for it to work again or it can just be reset
Posted on Sep 25, 2009
SOURCE: error message says printer error see
found this on another forum. I had the same problem and this worked for the problem posted:
Found this on techsupportforum.com and it worked for me. Good Luck!
Press and HOLD all following buttons: Power, Load/Eject (I don't have this button, so I skipped this), Stop, B&W, Color. Continue to hold the buttons until "Init Eeprom" appears on the printer screen. Press Color button to clear protection counter.
The panel then told me to press the power button, I did. When it came back up, everything was fine.
Posted on Jan 12, 2010
SOURCE: Get an error message
I found this on another forum because I had the same problem. This solved the problem and hopefully will solve this error message too.
websnail
  • 419 Answers
SOURCE: When I turn on my Epson stylus CX6400, it has the
Do you have any other indicators such as flashing lights or similar?
My guess is that it MIGHT be a "service required" error meaning the waste pads are full in which case this guide may help..
There's a reset sequence you can follow near the end of the article which I'd try... If that solves it then you'll need to deal with the waste pads.. If not, you'll know it's something else and can report back..
Posted on Mar 23, 2010
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer not printing. Error message reads see your documentation may need service
Counter reach its preconfigured limit it is just, you have to reset the counter back to zero count. This feature could be attributed not to overflow the waste bin.
In your web browser search bar, key in " epson reset software" the uppermost link is the one. Read the tutorial before doing so.
Hope you get it easily.
May 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Printer reads-"Printer error-see your documentation"... no clue as to what to do.
pull the plug and unplug it again..or load and unload your cartridge..,or change the cartridge you using...maybe the printer don't recognize the printhead..
May 12, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Initial Charge message not seen
Sounds as though the printer is defective.
Call or email Epson Tech Support.
Feb 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer error
Does the printer print? and does the scanner scan?
Nov 02, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
281 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
