Question about HP Officejet 5610 All-In-One InkJet Printer
Print on both sides
I have an officejet J4550
print/properties/printon both sides/: ;"off" or "manual"
what does this mean? searching help index I cannot find "duplex", "two-sided printing" or "print on both sides"
I can print on both sides by printing odd-numbered pages, restacking to reverse order and then print even-numbered pages. Is there a better way?
Thank you for your help. Richard
  • 417 Answers
SOURCE: duplex printing on HP Laserjet 2840
This is the natural process for the you the user to make sure that you have the correct media in the manual feed. You can change this in the paper handling menu within the menu options set the tray 1 media type to plain and auto continue also correct paper size. You can also put the paper back into the main cassette and this will not cause the problem.
Thanks J
Posted on Jan 28, 2008
  • 2785 Answers
SOURCE: HP laserjet 5000 series PCL 6 driver
have you tried from the print command dialog box from pc
Posted on Apr 28, 2008
  • 5568 Answers
SOURCE: Duplex printing problem HP 1320 TN
We have tried changing all the possible drives,
Did you mean drive rollers or drivers?
Since you are seeing the problem with multiple printers, I don't think the printers are at fault but rather the Windows driver for them - have you tried deleting that printer from the system and letting Windows 'find' it again?  If not, go to the printers and faxes folder of the control panel, delete any listing of this printer model, make sure the printer is on and connected, then reboot the system. This should force Win to reinstall the driver for this unit.
If that didn't help, cruise the HP website and look for discussions or tech notes regarding this printer. I'm fairly sure you aren't the only victims.
Posted on Sep 23, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: Laserjet 4250dtn Duplex problem
How is the printer connected.
Please upgrade the firmware of the printer.
Please upgrade the firmware of the printer:
1. Download the firmware file from the following website and extract it.
Expecting that the printer is connected over the network:
Remote firmware update by using FTP through a browser
Complete the following steps to update the product firmware by using file transfer protocol (FTP) through a browser.
NOTE: The following instructions can be used on Windows or Macintosh operating systems.
Take note of the TCP/IP address on the EIO-Jetdirect page. The EIO-Jetdirect page is the second page of the configuration page printout.
Open a browser window.
In the address line of the browser, type ftp://<IPADDRESS>, where <IPADDRESS> is the TCP/IP address of the product. For example, if the TCP/IP address is, type FTP://
Locate the downloaded .RFU file for the product.
Drag and drop the .RFU file onto the PORT1 icon in the browser window.
NOTE: The product automatically restarts the firmware to activate the update. At the end of the update process, the Ready message appears on the control panel.
The following describes how to upgrade firmware in the LaserJet 2400, P3005 and 5200 Series Printers using a USB connection only.
To send the firmware upgrade via USB, you will need to know the name of the computer the printer is connected to, and the printer will need to be shared.
To find out the name of your computer:
Click the Start button, Programs, Accessories, System Tools, then choose System Information.
You will find your computer’s name in the right window-pane next to System Name.
Write down this name as it will be needed later.
To share the connected printer:
Click the Start button, Settings , then choose Printers ("Printers and Faxes" on WinXP).
Right click on the printer you need to send the upgrade to and then choose Sharing.
On WinXP, if you encounter the following link "If you understand the security risks but want to share printers without running the wizard, click here.", click the link.
Select "Just enable printer sharing" and click OK .
Select Shared As: ("Share this printer" on WinXP) and type a name for the share.
Click Apply and write down the share name as it will be needed later.
To send the firmware upgrade using a USB connection:
Go to a DOS Command Prompt and locate the directory where you saved the firmware file. (To open a Command Prompt inWindows 2000 or XP, go to the Start button, then choose run, then type CMD and hit Enter, in Windows 98 or ME, go to the Start button, Programs, Accessories, then choose MSDOS Prompt). This will bring up a small black screen as displayed below:
If connected to a USB port, Type: copy /b filename \computer nameshare name (for example, copy /b ozfw.rfu \computer1printer).
Press ENTER .
The control panel displays receiving upgrade followed by performing upgrade . The download may take several minutes.
The control panel displays processing job .
The download is complete when the printer reboots and "READY" message is displayed on the control panel.
Posted on Oct 30, 2008
  • 2120 Answers
SOURCE: P3005n prints one sided fine, but jams in fuser on duplex
Lower the rear door ALL THE WAY DOWN past the 2 stops
Remove the 2 screws, pull off rear cover
Remove the small left rear cover and small right cover
Unplug the 2 small plugs on the right side.
Remove wires from white clip.
Remove large white plug on big circuit board
Remove 2 screws and pull out fuser
Look for a switch knocked off
Posted on Feb 14, 2009
I am getting a "No Scan Options Menue" it tells me to refer to device documentto troubleshoot. I don&#39;t have the document, any longer.
I have managed to find a user guide for the Officejet J4580, which is what a search on the HP website brings up. You can download it here:
and save it to your computer for future reference.
Hope this is helpful, if so would you please register that with Fixya
Dec 30, 2014 | HP Officejet J4550 All-in-One Inkjet...
Officejet J4550 Info How do I remove a paper jam? There is no manual.
i will give you the document and also the address for the manual which you can download
this URL is for clearing paper jam -
this URL is for the manual for your j4550 printer to download it-
hope this will gt you in business
thank you ..................god bless you ...(HAMID)
Oct 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Print Cartridge Problem
Wipe the cartridge using cotton.Clean also the wiper inside.
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
How do I find the Manuel for the HP OfficeJet Printer J4550?
CLICK HERE for a User guide PDF.
CLICK HERE for a Setup guide PDF.
All the above are for your HP J4550 Printer.
Thank you for using FixYa - A FixYa rating is appreciated!!
Feb 08, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
113 people viewed this question
Ben Johnson
