Question about Kenmore 22642 Top Load Washer
Model 110.2880389 water won't shut off when filling. Have replaced water level knob but still won't quit filling.
  • Kenmore Master
  • 2,295 Answers
You need to change the water level switch part number 3366845 and it's around 31 bucks,take out the two screws and flip open the top console,you'll see the water level switch,a clear plastic line is going to it,pull off the line but first check the line to see if it fell off or has any holes in it,it works by pressure,if the air is leaking out through a hole or something the water will keep filling,if the line is ok change out the switch.you can take the line off the switch and blow into it to check for a hole,let me know how you make out
Posted on Sep 01, 2010
  • Sal DeAngelo Sep 05, 2010
    did you find the problem?
  • Sal DeAngelo Sep 16, 2010
    also had a washer that was filling and agitating at the same time,they had a bad timer
Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Sep 06, 2012 | General Electric GSH22JSXSS Stainless...
Water is not coming in to washing machine when Start knob is pulled. When I disconnect both hoses, water is coming through faucets. Spin cycle is working fine.
ok
Two things control the fill. The fill "solonoids " ,hot and cold, via the temp selector
and the water level switch.Check cold only. If you get cold then your problem is definitely hot solonoid or temp select switch.If you get no water of any temp
then suspect water level switch and or temp select.Water level switch is behind console.Sometimes just turning level knob will get it to work . In any case, remove console and find the large switch with the small tube attached to it. If that tube gets kinked or clogged the machine won't stop filling.Your problem is the opposite. The switch thinks the tub is full. To test the swich, pull start knob.Put a volt meter or simple test light to one side of switch and ground, Then do same test on other side of switch.
There should be voltage available on both sides .If voltage on one side. replace switch.If voltage on no sides, the problem is the timer.(Not likely)Remember ,this test there is live electricity use extreme caution please!
Hope this helps
Sep 15, 2011 | Washing Machines
I get error FE- book says unplug and call a tech. Is this something I can fix myself?
FE error means that the water is filling past it's set point. You may have a broken water valve that won't shut off when it's in the filling mode. You can check by running the washer and watching the water fill. If the water level fills above the bottom of the glass, you have a water valve that's not shutting off. Replace the water valve.
Aug 21, 2011 | LG WM2487H Front Load Washer
Whirlpool utlra care II clothes washer shuts off when filling - push knob in and pull out it starts again - once full it completes remaings cycles
Hi, the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Nov 17, 2010 | Whirlpool Washing Machines
Maytag washer model MAV6451AWW - water does not shut off when filling. This started happening after I replaced the main control knob (knob works ok now) could I have loosened another connection which...
This problem is caused by a faulty water level switch.
It is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub.
As the water level increases, pressure increases on the air in the tube. When the pressure reaches a certain level, it activates the switch to turn off the water and signals the timer to start the agitate cycle.
Look for any obstruction or defect in the tube. The switch can be checked for continuity with a multimeter. If it has no continuity the switch is defective..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 16, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
if it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
May 09, 2009 | Whirlpool WTW5560SQ Top Load Washer
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
May 03, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer does not stop filling with water when it is set at the top two settings for larger loads.
ck to be sure small hose on water level switch is secure ..does water shut off when timer knob is pushed in?if not suspect fill valve stuck open if it does shut off suspect water level switch no repair just replace
Oct 25, 2008 | Washing Machines
Kenmore 22642 Top Load Washer Logo
91 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
