Question about Goodman CLQ36AR49 Air Conditioner
Fuse on control module blows when calling for cooling
I have a 4yr old GMS9/GCS9 furnace and a GSC130361D condensing unit. The problem is when we call for cooling the fuse on the integrated control module blows yet I can run the furnace or the fan and it fine. Any suggestions?
    Guru:
  • 415 Answers
Yes.
Disconnect the the red and the yellow wires at the outdoor unit. Then replace the fuse and turn on the power.......see if the fuse blew. If the fuse blew, your problem is most likely a short in the low voltage wiring. Check for crimped or damage wire or wire insulation and repair as necessary. If the fuse is okay, then the problem is within your outdoor unit.......again inspect all wiring for any damaged insulation or crimped wiring.
Check these items and let us know.....we can guide you further after you perform these checks. :-)
Posted on May 26, 2010
My Goodman GMS9/GCS9 Gas-Fired Furnace is not working.?
Check all safety switches on door. Make sure the main breaker in fuse box is on and well as main switch on furnace. Please ad more details. New install, just quit working? How old....
Oct 27, 2013 | Goodman GMS90703BXA Heater
I have a goodman high efficiency furnace, model gms9/gcs9. I've had several furnace techs look at it scratching thier heads. It won't fire up, the ignitor comes on but won't flame the unit. I...
check to see that your condensate line is not plugged. next check the p-trap where your line goes in. also check your flue abs flue pipe see as it comes out of roof is it open or does it have an elbow coming off of it i usually install with elbow preferably less water goes in the units resevoir hope that helps u
Apr 04, 2012 | Goodman Heating & Cooling
Furnace GMS9/GCS9 Cycles twice and then fires up most of the time and then it won't fire and shuts down. To restart it We have to shut the 110/115 power off for a few seconds and turn it back on and it...
Furnace ignition controls will attempt to light the furnace 3 times with several minutes delay between each attempt. If it fails to light or the ignition module fails to detect it lit after the 3 tries, the module will lock out and require a "Hard Reset" to try again. It is a common feature in nearly all newer furnaces intended to let you know you have a serious problem. You should call a service technician for this because there are a number of things that may be causing this flame failure. Please grade my answer on how much I have helped you. Thank you for the opportunity. Roger
Apr 04, 2011 | Goodman Heating & Cooling
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
Why wont it get cool inside no cool air is blowing
Make sure the filter is clean and the circuit breaker is on. Is the condensing unit out side on? Is the blower fan in the furnace /air handler on? If it's not a dirty filter or a bad fuse / tripped breaker, you will need to call a service tech. I know this might not be much help. It could be lots of things.
Apr 13, 2010 | Mastercool 67471 Evaporative Cooler Air...
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
I have a Goodman GMS9/GCS9 Gas-Fired Warm Air furnace and it's no
For anyone who finds this question in the future - It's the condensate drain hose for the heat exchanger.
Get a bucket and some towels handy and unplug the lowermost flexible rubber hose - if you do this right after the furnace has stopped, water will come gushing out. Mine was continually plugging up causing my furnace to stop, like yours - the L shaped plastic tube that dips into the drain trap on the outside of the unit (the thing filled with water) was too close to the bottom of the trap. I took it out, shortened it by 1/2 an inch (keep the same bevel that's on there!) and I haven't had a problem since. Blowing out the line would only hold things off for a few weeks before it started acting up again.
Cost me $90 for a service call the first time since visually it looks fine and I checked the upper hoses that go to the pressure switch :)
Learn from my service call!
Feb 23, 2009 | Goodman GMS90703BXA Heater
How to manually relight a Goodman® GMS9/GCS9 Single-Stage, Multi-Speed Gas Furnaces
You should NEVER attempt to relight manually this furnace. Serious burns could be the result. This furnace has an electronic ignition and should light by itself. If it does not light you may have a bad ignitor. These are usually around 30-50 US dollars.
Jan 28, 2009 | Goodman GMS90703BXA Heater
No y connection on furnace module to connect a.c. This is on a goodman model gmp075-3 furnace. I bought the b18099-13 replacement module and still no y terminal. I dont know were to land the t-stat...
"Y" terminal at the stat feeds condensing unit outside, common from the condensing unit to common on the furnace transformer.
"G" terminal on the stat brings the fan on for air circulation. In cooling mode "Y" terminal also brings the fan on. If this furnace was not A/C ready check the VA capacity of the transformer. Should be about 40VA. Make sure there is a fan relay to bring the fan on in the cooling mode.
May 01, 2008 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
167 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
