Question about Sony Playstation 3 (PS3) Console
I have a problem with my PS3 System. When I turn
I have a problem with my PS3 System. When I turn the console on nothing happens, I get a black screen. I checked all plugs and it seems not to help would anyone have any suggestions on how to fix this prblen?
Thanks
    President:
  • 2,653 Answers
You can try two things easily:
While the PS3 is off (solid red led) hold down the power button until you hear the SECOND beep, quickly release.
If that doesn't work try it again with the hard drive removed from the PS3.
If neither suggestion solves your issue you can try hooking the PS3 up with different cables ( a/v or hdmi) but I have NEVER seen cables go bad, but still Sony suggests you try.
More than likely the issue you are experiencing is related to the GPU on the motherboard.
There is a DIY approach to fixing it but I suggest sending into Sony for a solid repair.
You can contact SONY @ 1-800-345-SONY
Hope this info helps.
Posted on May 26, 2010
Testimonial: "I give those a try, thank you"
I just had that same problem. for some reason our resolution on our tv changed. it's happened once before. we didn't change it but i noticed when i switched to the ps3 that it was only 480p instead of 1080i. we went into our tv settings and changed it back and it is working fine now.
Posted on May 27, 2010
It turned off in the middle of COD Black Ops & now nothing happens. There is no lights or anthing when I try to turn it on
NO lights? must be a power issue. But you were playing black ops when this happened? interesting. There have been reports of Black Ops causing problems on PS3. Many believe that the game makes the processors work too hard, causing premature failure.
Feb 17, 2011 | Sony Playstation 3 (PS3) Console
I turn my ps3 on but there is nothing just black screen .how i can fix this problem
First off, you should try turning your PS3 off and removing the HDMI cable from the back of your console. Plug it back in and then restart your console to see if this fixes the problem.
If this does not work then you will need to try a reset on your console (NB- this should NOT delete your save games, gamer profiles etc, but I'm not taking any responsibility if that does happen by mistake)
Put your PS3 into standby mode, then hold down the power button until a series of beeps are heard. Release the button then restart your console. This is actually in the PS3 user's manual too, and it is unlikely that anything is seriously wrong with your PS3.
If you want more information about how to fix the PS3 black screen then visit my free PS3 black screen repair blog.
I hope this helps you to fix your console,
Regards,
James Philipson
May 29, 2010 | Sony Playstation 3 (PS3) Console
My ps3 keeps saying that there is a settings error to press X for it to be fixed when i press X the screan goes black and nothing happens
hold the power button at front when turned off, the ps3 will start up (still holding the power button?) then turn off again this will reset all system settings
Dec 24, 2009 | Sony Playstation 3 (PS3) Console
My ps3 turns black and nothing happens
Try checking your HDMI or VGA lead and reset the Ps3 Settings
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3 dead after firmware upgrade
You are going to have to upgrade the firmware manually..download it with your computer to a external hard drive.from the playstation website...then plug it in to your ps3.. it should upgrade automatically..
then if you say nothing happens you mean like black out??
if so then try doing this recovery boot.
Access the PS3 recovery menu
1. Turn off Playstation2.gif®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Please let me know if i helped you at all please vote.. thank you
Jul 15, 2009 | Sony Playstation 3 (PS3) Console
PS3 can turn on, but T.V screen is black
turn power switch on in the back. red light on in the front, hold the power button until system turns back off. this resets all hardware settings. if this doesn't work and the system is ok (green light) then you have a connection problem to the tv
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
Ps3 with black screen!
Yeah there is nothing to it. Just go up to your PS3 and hold down the power button untill it beeps. This should reset everything back to default on you system
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
when powwering on. hold the power button on the front of unit for about 15-20sec. that should reset back to factory settings
May 30, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turn on (green) but nothing happens.
Hi
Try to reformat your ps3 or reset the unit
Thanks!
Mar 10, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 screen black
Ah the PS3, a hive of problems with that little gadget. Well this problem is simple, check the connecting wires on the rear panel, make sure the cords are properly connected to the appropriate ports, also make sure they are free of any dirt or muck. If this didn't help, you may want to return the unit with your warranty card and exchange it for a new one. Sony hasn't completely finished designing the PS3 yet, in a few years they will complete a prototype of the newer version, just like what they did with the PS2, remember it used to be fat? Then came the Slimline which proved to be more reliable. That's what will happen to the PS3 soon.
Jul 01, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
305 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
