Question about Pondmaster HY-Drive Waterfall Pump, 2000 gph
Pump runs for 5-10 min and then shuts down.....I then have to wait anywhere from an hour to a day after it is unplugged to run again....is this fixable or is the pump done
    President:
  • 3,433 Answers
What is the Amperage and voltage of the pump? My e-mail address is co7196 at yahoo.com
Posted on May 26, 2010
Replaced the fuel pump. Car runs 10 min then shuts down. Acts like out of gas or pump. I wait 1 day and it starts fine for 10 min. I canhear the pump working.
run the fault codes and look for an EVAP problem not venting the tank
look also for a sensor problem that is failing from internal overheating problem from faulty components
Jan 02, 2017 | Cars & Trucks
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
My 95 ford f150 runs great till it warms up it seems then the fuel pump looses power n shuts down wait few mins kicks back on runs fine till few min later
Sounds like your ignition module it is common on fords to do this when its cool it will start and run fine but once it heats up the truck dies until you let it cool down again and then your up and running till it heats up again. Some modules are mounted on the fender others are mounted with the distributor have it checked and let me know how it went.
Aug 26, 2014 | Cars & Trucks
My 1995 jeep will die just driving and sometimes will start right back up other times you have to wait about an hour. fuel pump is working fine you can hear it
The pump can be running but not pumping any fuel.
When it stops running you will need to figure out if you are loosing spark to the plugs or fuel to the injectors.
Jul 27, 2014 | 1995 Jeep Grand Cherokee
Shuts down for no apparent reason
Have you figured out if you are loosing spark or fuel pressure when the engine quits ? Could be a relay, coil, fuel pump, or various other electrical components.
May 15, 2013 | 1992 Dodge Dakota
Bike leaves me stranded after 15 mins
Check your ignition coils. Sometimes they fail with an open circuit, this can sometimes close up when the machine is cold and open again when it heats up. So. it will start when cold and fail when it warms up.
Apr 24, 2013 | 1982 Yamaha XJ 650
Hi i have just fitted a eberspacher d4 to my boat it starts up well but after 20 mins it shuts down but will fire up again after a few hours ?
it could be that the fuel filter is cloged up or pump but theres defo a fuel problem is there any kinks in the fuel pipe i had a car that was doing same thing
Feb 19, 2012 | Heating & Cooling
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Pondmaster HY-Drive Waterfall Pump, 2000 gph Logo
140 people viewed this question
Top Pondmaster Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Pondmaster Garden Expert? Answer questions, earn points and help others
