Question about GPS
My Datron DBS-3000 antenna control unit has fried it's CR3 diode to an unrecognizable state. Can you help me determine the correct replacement part for this diode? The board takes 12V as input, and I assume the diode is used for protection as the logic on the board uses 5V. Thanks! mike
  • Mike Jardin May 26, 2010
    Thanks so much! I will do as you suggest. Mike
  • 12,061 Answers
Well I imagine that the veritable 1N4001 or 2 should fit the bill, quite well. IF it is a protection diode, However I wonder if it is not a ZENER Diode, and it is used to regulate the voltage, and more or less steps it down from 12 V DC to 5 V DC? Try a ZENER first, as it will still act as a diode, however the converse is not true. I would get myself a 1 WATT 5.1V Zener, (5.1V is a preferred value), and install that. If you still cannot get it to Go, then swap back to a 1N400*
Posted on May 26, 2010
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
How to check if alternator is working correctly
Absolutely DO NOT disconnect the battery while the unit is running. It usually kills the alternator.
There are a number of tests, the best being a bench test. But at 2,000 rpm, you should read 13.8 to 14.6 at the battery (WITH the battery fully charged). You would read less voltage with a low state of charge in your battery.
What fails in alternators commonly is diodes. These are one way valves for electricity, and convert the alternating current into DC, which your car needs. When one (of 6 or more) diode fails, there is a draw on the battery when the unit is shut down....The alternator does charge, somewhat, but not at full capacity. This is why a bench test really helps eliminate misdiagnosis.
Dec 23, 2012 | 2004 Volkswagen Jetta
Sanyo EM-SL40S microwave everything seems to be working fine but food doesn't get hot?
see this causes and fix it. GOD BLESS YOU
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Oct 01, 2012 | Microwave Ovens
Control board replacement
You may want to look at the following components on the circuit board and replace them as necessary. If there appears to be no power to the machine (clock), the machine may have received a power spike from an unclean/fluctuating power source. Look at resistor R5. If it shows any signs of heat damage, replace it. Then look at diode D3, which has been the cause of malfunction on my unit for four times already. Replace this diode (10V, 1.3W) and it should run again. This diode is working like an over-voltage protection fuse (which should have been built into this machine with easy access in the first place!) and since it gets fried so often on my unit I'm planning an illustrated writeup on how to mod the board to make exchanging this diode easier and without disassembling the machine.
Feb 21, 2012 | Cuisinart SM-55 Stand Mixer
MCS 95 SUBWOOFER WON'T POWER ON..REPLACED FUSE WHAT ELSE TO TRY
Concerning the Boston Suwoofer not powering up, I just had the same problem and this is what I did to fix it.
1. Uplug the unit
2. Remove the outer screws and remove the board unit
3. Unplug the board (Power Board) that is connected to the switch and unplug the two connectors that connect to the amp.
4. Remove the 4 screws(on the front panel side not the nuts on the board)
5. Look at the switching diode (labeled #1) directly beside the transistor cooling plate, if the board around this transistor is burnt there is a good chance that the diode is fried. If you do not trust your eye you can measure across the positive and negitave of the diode with your multi-meter (on the diode check setting) and you should read ~.565 and you should read infinity if you swap the leads. If the diode reads ~.667 and you can read this taken across any polarity the switching diode is fried.
6. If the diode is fried go to radio shack
7. Purchase a 1N914-1N4148 Switching Diode. Cost about $1.36.
8. Go home de-solder the fried diode.
9. Solder in the new Diode. ***Pay ATTENTION to put the new diode in the exact way the old one came out!!*** If you do not get the polarity correct the diode will not work properly and your unit will not power up. Also, it is a good idea to leave ~ 1/8" between the diode and the board, this will help disipate heat the cause of the problem to begin with.
10. Place power Board back on the backside of the front panel
11. Install 4 screws(on the front panel side not the nuts on the board)
12. Plug the board (Power Board) that is connected to the switch and plug the two connectors that connect to the amp.
13. Place the panel back onto the subwoofer and secure it with the screws. You can use a screw gun for this just make sure to turn you tourqe level back to ~3 otherwise you could strip out the screw and or the particle board.
14. Plug it in and your rolling.
I hope I am not to late and this works out for you. I just fixed mine tonight.
Nov 01, 2011 | Audio Players & Recorders
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Keyboard keys are incorrect when not attached to a usb keyboard
Go to the control panel > Language and Regional Settings > go through each and every setting and make sure that the entries are for English-United States. In keyboard tab, make sure that the english keyboard is the only one listed, remove all others. Make wure that the location is United States. Be sure the time and time zone are correct for the computer.
Oct 26, 2009 | Lenovo 3000 V100 Notebook
No television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
Nov 21, 2008 | Denon AVR-2106 Receiver
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Mar 19, 2008 | JVC RM-C18G-1H Remote Control
GPS Logo
123 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
